Home > Td5 > Overhauling the starter solenoid |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1768 |
I'd take it off personally, removing the top bolt is the difficult one, if you can source an assistant it gets much easier!
My method is to have a person underneath with a ratchet and a long extension, and the other person reaches in from the top to guide the socket onto the bolt. |
21st Aug 2017 10:37am |
15mm socket 6 point type ^
21st Aug 2017 12:35pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 637 |
Removing the starter is a bit hard, because of the top nut. Replacing the solenoid internals with starter still in car is possible, but it is a bit blind-work. I have done it once on Discovery2, after 1 hour long fight with the top bolt. Some years later, we had to remove a lot of parts from engine to remove the top bolt. And we found, that some used some thread locking glue on the nut.
3/8" 15mm nut is the key tool. "Drobek" = The Small One - Discovery 2, "BlufÃnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
21st Aug 2017 1:22pm |
stigomery Member Since: 10 May 2016 Location: Cambridge Posts: 277 |
Cheers chaps
Does it require a flexi/UJ extension bar or will a simple straight extension do the trick on a 3/8" ratchet? |
21st Aug 2017 1:34pm |
Flat ratchet and extension with the right length. No need for any flex.
I have bought 1/4" 15mm nut and it is even easier, but 15mm is not easy to buy in 1/4" size. "Drobek" = The Small One - Discovery 2, "BlufÃnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
21st Aug 2017 6:24pm |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 |
I've done a couple of these on my 300tdi, to be honest, it would have been cheaper and easier just to get a new starter straight away rather than keep on paying for solenoids and then eventually a new starter, the replacements just didn't last 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
22nd Aug 2017 6:12am |
I have better experience - during last 5 years I have made quite a few of these solenoid repairs, without any return. 50/50 I made also at least clean and re-grease of the starter gearbox. 50/50 only, because on half of them the screws were so tight, that I let it be, rather then breaking them. "Drobek" = The Small One - Discovery 2, "BlufÃnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
22nd Aug 2017 6:19am |
Really? Starter motors for the Td5 are around 150 quid, the repair kit is 14 quid. My starter motor was replaced in 2013 so i would expect a lot more life out of the unit itself than 4 years. It's just a sticky solenoid and a tap with a lump of wood frees it when it happens (twice in the last 12 months)... for now a repair will do me... |
22nd Aug 2017 6:58am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
22nd Aug 2017 8:55pm |
May be different, but the only solenoids I could find were £30, where did you get one from? I got a starter from here, has been really good https://www.directautoelectrical.co.uk/par...amp;cat=12 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
23rd Aug 2017 5:41am |
Linky:
X8R |
23rd Aug 2017 8:00am |
rsms Member Since: 12 Jan 2013 Location: Home Posts: 36 |
Hello,
I am in a process of replacing starter solenoid in my TD5 and this would be the right time to re-grease the gearing part of a starter. Looking for some advice on what grease would be suitable for inside gears /shaft? Thanks! |
25th Apr 2024 12:53pm |
