Home > Td5 > Overhauling the starter solenoid
stigomery
United Kingdom 2004 Defender 90 Td5 HT Belize Green
My starter solenoid is on the way out and I have a service kit ready to deploy. I was going to do it at the weekend and had assumed I could probably do it in-stiu, in fact I'm sure I've read instructions on doing so somewhere but cannot find them.
Once I had the front wheels up on ramps it became clear it was a lot tighter in there than I thought.
Having read that getting the starter motor off can be a real ball ache is it possible/wise to do in situ or should I dedicate a day (yes, I might be that inept) to getting the starter off and doing in on my workbench?
Post #645384 21st Aug 2017 11:14am
miker
I'd take it off personally, removing the top bolt is the difficult one, if you can source an assistant it gets much easier!
My method is to have a person underneath with a ratchet and a long extension, and the other person reaches in from the top to guide the socket onto the bolt.
Post #645390 21st Aug 2017 11:37am
dorsetsmith
15mm socket 6 point type ^
Post #645421 21st Aug 2017 1:35pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Removing the starter is a bit hard, because of the top nut. Replacing the solenoid internals with starter still in car is possible, but it is a bit blind-work. I have done it once on Discovery2, after 1 hour long fight with the top bolt. Some years later, we had to remove a lot of parts from engine to remove the top bolt. And we found, that some used some thread locking glue on the nut. Shocked
3/8" 15mm nut is the key tool. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #645425 21st Aug 2017 2:22pm
stigomery
Cheers chaps
Does it require a flexi/UJ extension bar or will a simple straight extension do the trick on a 3/8" ratchet?
Post #645426 21st Aug 2017 2:34pm
MadTom
Flat ratchet and extension with the right length. No need for any flex.
I have bought 1/4" 15mm nut and it is even easier, but 15mm is not easy to buy in 1/4" size. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #645488 21st Aug 2017 7:24pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I've done a couple of these on my 300tdi, to be honest, it would have been cheaper and easier just to get a new starter straight away rather than keep on paying for solenoids and then eventually a new starter, the replacements just didn't last 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #645582 22nd Aug 2017 7:12am
MadTom
I have better experience - during last 5 years I have made quite a few of these solenoid repairs, without any return. 50/50 I made also at least clean and re-grease of the starter gearbox. 50/50 only, because on half of them the screws were so tight, that I let it be, rather then breaking them. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #645583 22nd Aug 2017 7:19am
stigomery
Really? Starter motors for the Td5 are around 150 quid, the repair kit is 14 quid. My starter motor was replaced in 2013 so i would expect a lot more life out of the unit itself than 4 years. It's just a sticky solenoid and a tap with a lump of wood frees it when it happens (twice in the last 12 months)... for now a repair will do me...
Post #645594 22nd Aug 2017 7:58am
Screbble
Post #645748 22nd Aug 2017 9:55pm
Dave T
May be different, but the only solenoids I could find were £30, where did you get one from? I got a starter from here, has been really good
https://www.directautoelectrical.co.uk/par...amp;cat=12 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #645793 23rd Aug 2017 6:41am
stigomery
Linky:
X8R
Post #645826 23rd Aug 2017 9:00am
rsms
Slovenia
Starter motor gears grease
Hello,
I am in a process of replacing starter solenoid in my TD5 and this would be the right time to re-grease the gearing part of a starter.
Looking for some advice on what grease would be suitable for inside gears /shaft?
Thanks!
Post #1032803 25th Apr 2024 1:53pm
