Home > Maintenance & Modifications > Main Light Switch
mattlynch
England 2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Main Light Switch
I know this is a well documented weakness in the defender but I have query regarding the speed at which these switches 'burn out'
2 weeks ago my SVX developed the problem with no lights when the switch is in the full on (dipped) position, but one click back (sidelights) still worked fine.
Stalk still worked fine as was able to flash full lights.
After consulting this fine forum I gathered it was probably the switch at fault, so sourced a replacement one.
Opted for a Lucas one (not the cheapest - Britpart and certainly not the most expensive - Land Rover)
Again this forum gave me pointers on how to change it, which went without issue and sorted the problem. Very Happy
HOWEVER......
It has been only 3 days following replacement and the problem has recurred Big Cry
Does this mean I have a short in the wiring elsewhere Confused or have been unlucky with my replacement item. Crying or Very sad Matt,
09 Defender 90 SVX
01 Discovery 2
Post #644739 17th Aug 2017 5:53pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
They can last from 10min to 10 years... its down to luck..
Only way to find out is to get a multimeter and test the amps going through the pins on the light switch socket, should be around 13-15 amps I recon but not really sure exactly.
Post #644745 17th Aug 2017 6:44pm
VeeTee
Netherlands
My record is 0 min ... Shocked
After mine burned out, the new replacement I bought (non genuine) was dead on arrival... So bought the proper one, and installed a wiring loom with relays at the same time.. This was 8 years ago, and still all good (though I must say I now have all LED lights all around). Thumbs Up Cheers, Vincent
MySite
Post #644747 17th Aug 2017 6:53pm
^^^^ This is best, and for long term also. $W33T $0U7H3RN $UG4R
Post #644763 17th Aug 2017 8:16pm
Eduardo
As per others...
Can last 1 week, 5 months or a year or 2.
To solve it I installed a loom with relays around 1 year ago and no more problems. Very happy Smile Eduardo
Post #644944 18th Aug 2017 9:24pm
rallysteve
Lucas branded stuff is no longer the same lucas of old. Believe it is all chinese made now. 02' 110 TD5 Double Cab Rebuild Thread
Post #644989 19th Aug 2017 7:18am
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
I worred in Iran in 1978 and the Genuine Lucas parts in the green and white box were exact copies but called Rucas.
Post #645007 19th Aug 2017 9:30am
