Home > Maintenance & Modifications > Wet carpets near doors.....?
Page 2 of 2 <12
zsd-puma
V8Smith wrote:
So looking at the site, its telling me for the front doors I need two of part No LR029309 for the two front doors, then it tells me I also need, LR029307 and LR029308 for the rear doors
So then do I also need LR024954 & LR024955? As these were mentioned by Greenlandrover above
Just want to make sure I get what I need, as carpets are wet and don't want the carpets to get mouldy
Mike
The top 3 part numbers are the latest type bottom door seals. The other two are the main door seals, you wont need those unless yours are in poor condition.
Quote:
Would recommend that you try and trace the leak before spending money on seals.
So would I, although the revised bottom door seals are far better than the old ones, not just for keeping water out, but also for reducing cabin noise and draughts. They definitely a worth while upgrade even if they're not the reason for your wet carpets.
Post #644605 17th Aug 2017 2:10am
Google: Land Rover defender water ingress
You will find a PDF with all the info you need to trace water leaks
Linky http://www.landroverweb.com/Pdf-files/Manu...Manual.pdf
Post #644614 17th Aug 2017 6:31am
Page 2 of 2 <12
