![]() | Home > Td5 > Mantec Spare Wheel carrier |
Chris90V8 Member Since: 02 Oct 2016 Location: Suffolk Posts: 714 ![]() ![]() ![]() |
Alot quieter
![]() Really chuffed with the results 🚜. ...... . .... . .. 🚗ðŸšðŸš›ðŸššðŸššðŸš—🚙🚠|
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5276 ![]() ![]() |
what piece do you need to buy extra for the alloy wheel if you are going Mantec? i am going to get one at some point when the funds are back up and what is the best way to seal off where you have drilled? ( when you remove the rivets on the capping) Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello Procta
Alloy Wheel... ![]() It depends on what you have, if they are Standard LR Alloys, that fit Standard Hubs and Wheel Stud Pattern, then your Alloys will fit the Mantec. If you have an Alloy that requires a Hub Adapter to give a different PCD Stud Position, then you just need to replicate this on the Mantec. If your Alloys are non Standard they may have an Off Set (ET Value) then this needs to be factored in as well. To keep it simple a Standard LR Alloy (and Stud Pattern) will Fit the Mantec...if you have any kind of Spacer / Adapter fitted then take one off your Defender fit it to the Mantec and check your Spare fits OK...get creative if it doesn't. Sealing the Two Holes... ![]() The holes are through a combination of materials that form this junction, The Aluminium Body Panel (Birmabright) and the Steel used in the Cappings. I just used a body colour touch in kit, getting the paint in between the layers as best as possible before they were 'clamped' up with the Mantec Bolts. You could use a product like AFC 50 here instead (much praised on D2N ![]() I also added a short flat Al' 'Strap' behind the left hand hole (from the inside) to spread the loading and bring the two holes to a similar condition...not really necessary but it just felt better. ![]() Click image to enlarge Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
⬆⬆⬆⬆AFC50 is the stuff that flows in God's veins
![]() 🖒👍🖒👍🖒👍🖒👍 🚜. ...... . .... . .. 🚗ðŸšðŸš›ðŸššðŸššðŸš—🚙🚠|
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3069 ![]() ![]() |
What's the best price people have bought these for?
My local dealer has quoted me £300+VAT |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 ![]() ![]() |
I paid £179 for one from a well known auction site
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7918 ![]() ![]() ![]() |
FLat Dog is selling the genuine Mantec spare wheel carrier for £238 inc vat (and free fitting if you visit them). James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Hello lightning
What Year Defender do you have... ![]() The Mantec Spare Wheel Carrier has 2 versions... Up to 2001 (2 piece rear door) Post 2002 (1 piece rear door) SKIP https://www.defender2.net/forum/topic83242.html |
2005 TD5 110 CSW
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3396 ![]() ![]() |
PA Blanchard flog them for £125:
https://www.pablanchard.co.uk/shop/product...R0130.html They are quoted as 'Genuine' landrover parts and are Mantec. ![]() |
£125 plus VAT, unfortunately, and £10 delivery. Darren
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 ![]() ![]() |
You say "unfortunately" but I think £160 vs £238 sounds a reasonable saving if it is the exact same item?
Of course, but it's unfortunately a lot more than £125, which was the suggestion. Darren
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
Careful, that's VPLDR0130 for steel wheels only, that's why it's cheaper, I believe it fits differently and you can only use it with upto 235/85/16 tyres 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
