Home > Td5 > Mantec Spare Wheel carrier
Page 2 of 3 <123>
Chris90V8
England 1987 Defender 90 2.5 TD XS CSW Portofino Red
Alot quieter Bow down
Really chuffed with the results ðŸšœ. ...... . .... . .. 🚗ðŸšðŸš›ðŸššðŸššðŸš—🚙ðŸš
Post #643676 13th Aug 2017 7:37pm
V8GPC
Thumbs Up for Mantec,
I bought the Britpart one prior, its the same design (or a copy) of the mantec, but it didn't fit.
In the end the whole assembly was welded wrong; after taking mesurments from another vehcile to confim it wasn't my LR.
It was returned and swapped out for the mantec which fitted easily.
Post #643782 14th Aug 2017 7:12am
Procta
what piece do you need to buy extra for the alloy wheel if you are going Mantec? i am going to get one at some point when the funds are back up and what is the best way to seal off where you have drilled? ( when you remove the rivets on the capping) Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #651185 19th Sep 2017 1:39am
X4SKP
Hello Procta
Alloy Wheel... Question
It depends on what you have, if they are Standard LR Alloys, that fit Standard Hubs and Wheel Stud Pattern, then your Alloys will fit the Mantec.
If you have an Alloy that requires a Hub Adapter to give a different PCD Stud Position, then you just need to replicate this on the Mantec. If your Alloys are non Standard they may have an Off Set (ET Value) then this needs to be factored in as well.
To keep it simple a Standard LR Alloy (and Stud Pattern) will Fit the Mantec...if you have any kind of Spacer / Adapter fitted then take one off your Defender fit it to the Mantec and check your Spare fits OK...get creative if it doesn't.
Sealing the Two Holes... Question
The holes are through a combination of materials that form this junction, The Aluminium Body Panel (Birmabright) and the Steel used in the Cappings. I just used a body colour touch in kit, getting the paint in between the layers as best as possible before they were 'clamped' up with the Mantec Bolts. You could use a product like AFC 50 here instead (much praised on D2N Thumbs Up ).
I also added a short flat Al' 'Strap' behind the left hand hole (from the inside) to spread the loading and bring the two holes to a similar condition...not really necessary but it just felt better.
Good Luck SKIP
Post #651225 19th Sep 2017 10:12am
Chris90V8
⬆⬆⬆⬆AFC50 is the stuff that flows in God's veins Rolling with laughter
🖒👍🖒👍🖒👍🖒👍 ðŸšœ. ...... . .... . .. 🚗ðŸšðŸš›ðŸššðŸššðŸš—🚙ðŸš
Post #651242 19th Sep 2017 11:19am
lightning
What's the best price people have bought these for?
My local dealer has quoted me £300+VAT
Post #651657 20th Sep 2017 10:14pm
Profyaffle
I paid £179 for one from a well known auction site Wink 1993 200Tdi Defender 90
Post #651695 21st Sep 2017 8:41am
JOW240725
FLat Dog is selling the genuine Mantec spare wheel carrier for £238 inc vat (and free fitting if you visit them). James
Instagram @suffolk_rovers
Post #651700 21st Sep 2017 9:15am
X4SKP
Hello lightning
What Year Defender do you have... Question
The Mantec Spare Wheel Carrier has 2 versions...
Up to 2001 (2 piece rear door) Post 2002 (1 piece rear door) SKIP
Post #651765 21st Sep 2017 12:39pm
lightning
2005 TD5 110 CSW
Post #651938 21st Sep 2017 10:02pm
camelman
PA Blanchard flog them for £125:
https://www.pablanchard.co.uk/shop/product...R0130.html
They are quoted as 'Genuine' landrover parts and are Mantec.
Post #651946 21st Sep 2017 10:16pm
£125 plus VAT, unfortunately, and £10 delivery. Darren
Post #651949 21st Sep 2017 10:37pm
bluebottle
You say "unfortunately" but I think £160 vs £238 sounds a reasonable saving if it is the exact same item?
Post #652211 23rd Sep 2017 7:27am
Of course, but it's unfortunately a lot more than £125, which was the suggestion. Darren
Post #652212 23rd Sep 2017 7:42am
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Careful, that's VPLDR0130 for steel wheels only, that's why it's cheaper, I believe it fits differently and you can only use it with upto 235/85/16 tyres 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #652256 23rd Sep 2017 11:21am
Page 2 of 3 <123>
