Home > Technical > High Level Stop/brake Light help (fixed)
Page 1 of 3 123>
Djcla
OK my High Level brake light is missing from 2002 TD5 ive found a replacement on ebay minus the plug bits that glue to the window. However id like to ensure the wiring is working and not 100% sure how i would check that i do have a multimeter though lol. There is a wire coming in on both sides but not entirely sure where they both go back to etc?
Post #641399 2nd Aug 2017 1:55pm
zsd-puma
put your multimeter with one probe on each of those large metal contacts and have someone put their foot on the brake (with the ignition on) if you get 12v then you should be good to go.
Post #641400 2nd Aug 2017 1:57pm
Djcla
ok thanks i thought the black lead on multimeter was for negitive so which side on my screen would that be?
Post #641407 2nd Aug 2017 2:26pm
It doesn't matter for this test, you'll get a reading of +12v if the red lead is on the positive and the black on the negative, or -12V if they are the other way round.
Post #641409 2nd Aug 2017 2:44pm
zsd-puma
It doesn't matter. If you connect it around the wrong way the multimeter will just display the voltage as a minus. So -12v rather than 12v. Either way for this purpose it means the same - there is power to the brake light.
If your multi meter has a continuity test function (most do), then put one lead to an earth on the body and the other to one of the terminals on the screen, when it beeps at you you've found the negative terminal.
If you have an old analogue meter, then if it doesn't work one way swap the leads around and try the other.
Post #641410 2nd Aug 2017 2:44pm
Djcla
Thanks all
Post #641412 2nd Aug 2017 2:46pm
If you use your black lead of your Multimeter to an earth point other than those contacts.
Set you Multimeter to detect voltage
Then ask somone to opperate the brake.
You should find around 12v on the positive side and 0v on the negative using your red lead on the Multimeter.
Then you've hopefully identified Power and what terminal.
If you want to check the earth, no need to use the brake this time do the same as above but set your Multimeter to continuity test, so it beeps when you touch the probes together.
Test the terminal you identified as earth and not the live, the reading should be as close to zero as possible and it should beep.
If it does nothing there is an earth missing or a poor earth.
My guess is both will check out perfect. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #641432 2nd Aug 2017 4:15pm
Djcla
Done some tests I get 2.5v to 3v at the light and 12v where the fire connects to glass at the bottom. So im guessing something ain't right maybe that's why the light git removed. Lol.
Post #641453 2nd Aug 2017 6:48pm
Sounds like a damaged copper track on the glass.
Quite a common issue.
A bit more expensive but I'd consider changing the window inc new bonded light in one hit.
Post #641464 2nd Aug 2017 7:21pm
Djcla
Got a link to tailgate glass with the light? Also can I assume it's not possible to fix copper track?
Post #641467 2nd Aug 2017 7:35pm
There are kits to do so but it's hit and miss and I think you'd find it such a pain in the backside it would be easier to replace.
I'd have a chat with Dave at VGS:
http://www.vehicleglazingspecialists.com/s...ducts.html
Or there is Genuine LR. Whilst you at it you may want to consider tinted or similar but the choices are yours. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #641470 2nd Aug 2017 7:48pm
Djcla
New rear tailgate glass is an option and tinted be good but then I'd need to get the other windows in the same tint . They seem to come with green tint so no idea if I'd get that matched.
To fix the existing would it not be a case of finding the break and applying copper conductive paint?
Post #641679 3rd Aug 2017 5:51pm
You could give it a go. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #641697 3rd Aug 2017 7:06pm
Djcla
hi all
revisiting this and was thinking if i run some wire around the edge of the window tucked in behind the seal and connect it to the female spade connector on the bottom right where it come up through the door card , maybe that could work. On the the left side though there is only one connector coming through to the window so its possibly shared with the heated glass does that sound right as on the other side there is 2 connectors?
Post #645387 21st Aug 2017 10:25am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
As you seem keen to fix what you have, then carry out the continuity tests on the metal track starting from where you have 12v. You should then find the break in the track, i.e. where the voltage drops to 2-3v.
I have successfully repaired a rear heated screen using the kit. The repair kits do work and if the gap is small you stand a good chance of a successful repair.
Post #645391 21st Aug 2017 10:39am
Page 1 of 3 123>
