Home > In Car Electronics > Fitting Parking Sensors NAS Rear Step
Page 2 of 2 <12
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi Stiff1
Answers to your questions
You can get the cross member cover plate from here.
http://www.landrovertrailair.co.uk/products/
The modified folding step is just fitted with bolts onto the under side of the NAS rear step.
No tow bar fitted at present but you can remove the additional folding step and fit a one without any issues.
The bracket on the right hand side is the lower mounting point for a spare wheel carrier that I hadn't re fitted when the pictures were taken.
Covers for the small holes in the cross member are just closed or blind blanking grommets from eBay or any good auto electrical supplier but I'm still trying to find some 18/19mm ones to suite the two centre holes.
Post #642154 6th Aug 2017 7:46am
bankz5152
Decided to drill out this bit, best position without masses of work. I know the sensor is blue, they sent the wrong ones lol so they make for good testers. Also know my step needs a touch up!
Post #642358 7th Aug 2017 10:34am
bankz5152
Thought I'd share a few pics now I'm finally done with the sensors!
Mounted in the jack mount, looks the neatest and safest for the sensor
Others mounted inside the chequer plate/rear corner, again quite protected but still useful
Switch so I can turn them off when off road
Post #644637 17th Aug 2017 9:31am
Stiff1
Nicely done, like the switch.
Post #644705 17th Aug 2017 3:26pm
Page 2 of 2 <12
