Home > Td5 > Will my Oil pump bolt fail? |
I am not sure that yours is in the danger range, but probably not as if it didn't fall out till now it probably won't fall out anymore unless off-course you hardly use it.
It is not that much work however to make sure it is right. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
1st Aug 2017 10:56am |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3373 |
I had a 2003 Td5 and the oil pump bolt came loose at around 90,000 miles.
Luckily the local indy spotted it before it caused serious damage! |
1st Aug 2017 12:05pm |
1st Aug 2017 12:12pm |
raider_td5 Member Since: 01 Aug 2017 Location: Islamabad Posts: 9 |
Went through both the links, very helpful. Thanks for sharing.
I will be ordering a new bolt and a gasket. Thanks! |
1st Aug 2017 4:45pm |
