![]() | Home > Puma (Tdci) > Intermittent engine warning light |
The only thing you can do is look for chaffed wires under the bonnet. Assuming you don't find any, then you've no way of knowing without plugging in a tester.
Smithy Member Since: 25 Jul 2010 Location: Monmouthshire Posts: 21 ![]() |
Word of advice don't drive it if the engine or oil illuminates get it into a garage asap.
The red oli light indicated oil pressure not level. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17711 ![]() ![]() ![]() |
Yes, it means you have a fault and need to plug in some diagnostic equipment! Not a very insightful answer I know, but that is all you can tell just from the light. There are hundreds of things that can cause this to happen, and without reading the associated fault codes from the ECU or any other symptoms (such as misfiring) any further attempt at diagnosis is pure guesswork. |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 ![]() ![]() |
Maybe it's a morse code
And if it is three brief flashes followed by three long flashes And then three brief ones..It maybe a distressed signal from your defender... .....If it's a 2.2 have you got the engine oil pump recall done? |
