Home > In Car Electronics > Which fuse.
L110CDL
Which fuse.
Hi all have done a mini search but not getting the answer Rolling Eyes
I have got XS heated seats and wanted to know what fuse they need ? I am also assuming that i dont need a relay as they are going to be on an on/off switch ?
I am not very good at reading circuit diagrams, get a bit confused Embarassed
Many thanks for your replys Thumbs Up Clayton.
Keeper.
Post #637863 16th Jul 2017 7:47pm
wyvern
Hi Clayton
I think most switches are ‘just on/off’ so that is not the issue, the power drain of the item is the issue and my heated seats have a high power drain and need a 30amp fuse and use a relay as, from what I can remember, as the power will go right through the switch and quickly burn it out.
Those who are more informed about the dark art of electricity will no doubt give more information and correct my post if I’m wrong
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #637871 16th Jul 2017 8:12pm
L110CDL
Thank you wyvern Thumbs Up Clayton.
Keeper.
Post #637883 16th Jul 2017 8:46pm
Alien
Australia
From memory for a Puma...
The power for the seats is through a relay activated by the ignition.
This cuts power when the key is off.
The same circuit has the power windows and rear wiper(if fitted).
I've bypassed mine to give me live windows, no ignition required.
The down side to the modification is if you have seat heaters they will drain the battery if left on when parked up. Cheers,
Kyle.
Post #637928 17th Jul 2017 6:13am
Profyaffle
As said previously.. you should use a relay. The switch should be connected to an ignition live which then goes to the relay to power the relay which allows the current to flow from the battery to the seats. Heres an article with some pics and a simple diagram Thumbs Up
http://www.briandorey.com/post/Wiring-Land...ated-Seats 1993 200Tdi Defender 90
Post #637992 17th Jul 2017 2:13pm
L110CDL
Many thanks Kyle Thumbs Up
Thank you Profyaffle Thumbs Up good article but it doesn't say what relays he used Rolling Eyes I'm assuming that it can be any on/off switch as long as it is wired to the ignition ? many thanks. Clayton.
Keeper.
Post #638077 17th Jul 2017 8:13pm
Profyaffle
I'm not sure which relay, my kit was all made up and I just had to plumb it in and connect to an ignition live and the battery power. Also my seats have a high and low heat setting so the switch has three positions (high, low, off). Do your seats just have one setting?
Mobilecentre do a few different heated seat looms.. Thumbs Up 1993 200Tdi Defender 90
Post #638239 18th Jul 2017 1:06pm
L110CDL
Thanks again Profyaffle Wink i dont know about the heat settings, but i hope to have an answer soon Embarassed only thoght there was one setting Rolling Eyes once i have found out i will give them a call and see what they can do for me Very Happy Clayton.
Keeper.
Post #638531 19th Jul 2017 9:29pm
