Home > Puma (Tdci) > Extra connectors in front wings |
mrandmrsh Member Since: 31 May 2010 Location: Huddersfield Posts: 692 |
For headlamp height adjustment (assuming yours doesn't have it??)
C |
14th Feb 2011 11:39am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17566 |
Thanks for the quick reply, but I should have made it clearer: there are two spare connectors in each wing - the headlamp adjuster motor connector is one and then there is an additional one that is the same as the side/indicator light connector.
The adjuster motor connector is a different shape to the light connectors. |
14th Feb 2011 12:01pm |
I think I have just found the answer - in the LH wing it is the connection for the rear screen washer pump. Mine being a DC, it has no rear washer pump hence a spare connector. Confusingly it is the same connector type as the lights, YPC10070.
I think I must have imagined the one in the other (RH) wing - probably got confused with the light connectors which were by then hanging free. Thanks anyway everyone! |
14th Feb 2011 12:09pm |
14th Feb 2011 1:28pm |
