- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
mata
Sounds like classic faulty VCV symptoms. If you search for volume control valve within these forums you'll find other with these symptoms which were relieved by a swap of the part and a fuel pump re-learn. I had one changed at Landranger which failed after a couple of years. Apparently the replacement pets vary in quality and you want to be replacing it with a Denso brand one. Also referred to as a suction valve and a fuel control valve. You can diy the swap with an average socket set but access is a bit of a , it helps if you've got child sized hands. You then need to a computer to tell the ECU to relearn the characteristics of the fuel pump, a bought a cheap ass one called a Foxwell on a bit of a limb and it indeed had this function and worked well. The guy who is Bell Auto Services was extremely generous with his time and expertise over the phone and I believe he sells replacement valves and his reprogramming tool can also perform the fuel pump relearn
15th Aug 2017 3:45pm |
