Home > Series Land Rovers > Rusty the S2a - The rebuild thread.
Page 1 of 4 1234>
Tiger
So this is Rusty a solid but tatty 1966 Series 2a
Post #634645 30th Jun 2017 11:35am
ickle
Remove the steel, clean the aluminium up well and protect it and it will stop.
An insulating layer that ideally stops water getting into the joint and forming an electrolyte between the dissimilar metals will stop it in the future.
Post #634647 30th Jun 2017 11:39am
Tiger
For context I've cut out the steel battery box form my Series 2 and replacing it with an Aluminium version.
Where it had previously been in contact there is some dreaded white powder and most of it will come off but even after wirebrusing / flappy disc there will still be 'pits' where it is quite deep.
Old Battery Box (Swiss cheese model)
New Shiny Aluminium one
Seat Box
Post #634648 30th Jun 2017 11:46am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Neat construction job. But don't forget that your fixings need to be protected if steel.
Original box/ supports in not too bad condition for 50 years old though!
Post #634665 30th Jun 2017 12:37pm
ickle
As above, nice job, just for total clarification it is aly not a YRM stainless jobby?
Anyway, clean it back, prime and sikaflex/tiger seal the joints and it will outlast us all!
If it is a stainless version, or for anyone who is bored enough to be reading this far, treat stainless the same as steel, prime it, drill, debur and remove the swarf, sikaflex fill the joint, rivet the two together, clean up and then wish you'd remembered to wear gloves for the next two weeks as the stain wears off your fingers.......
Good luck
Keith
Post #634667 30th Jun 2017 12:43pm
Tiger
Defiantly Aluminium Smile It's very light and bends easy.
The black stuff is Sikaflex, it's already on my hands Whistle
Post #634670 30th Jun 2017 12:51pm
Tiger
A few more photos
Sanded / wire wheeled the corrosion back, etch primed and filled with a bit of body filler.
Also where I'd replaced the side section I had to drill out the spot welds, at first I put some pop rivets in but these looked crap so I drilled them out and replaced with countersunk aircraft rivets. Really please with how they are looking like the original spot welds Thumbs Up
I reckon when sanded and painted it will look pretty much original
Post #634766 30th Jun 2017 7:18pm
ickle
very smart!
Post #634804 30th Jun 2017 9:39pm
Tiger
Bit more work replacing the rear strengthening angle bar at the rear of the seat box.
Post #635136 2nd Jul 2017 7:01pm
Tiger
Okay, managed a bit more time on the beatbox refurb
Thumbs Up
All rivets are now original Domeheads (apart from 2 pops which I'll fill) and ground in some 'fake' spot welds where the countersunk rivets are.
So far pretty pleased
About to position new battery box
Clamped up
arrggghhhh! Sikaflex!!
Grinding in spot welds
Primed
Post #635805 5th Jul 2017 6:52pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Top job that man Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #635807 5th Jul 2017 7:14pm
Tiger
Cheers Thumbs Up
Guess what the next job is Big Cry
Post #635815 5th Jul 2017 7:25pm
ian series 1
What's the tub like? Confused
My pet hate.... Big Cry 80" 80" 86" 88" 90"
Post #635817 5th Jul 2017 7:29pm
Tiger
As you'd expect for 50 years old really
The crossmember beams are crusty but seem solid enough I'm hoping some rust convertor will lengthen their life.
The wings are a bit dinted and I can't work out how to straighten them, they have a spring memory which means body filler won't work and they are too thin and flexi.
Where it's attached to the chassis that's quite powdery and holey
Not sure of a plan of attack yet...
Post #635819 5th Jul 2017 7:35pm
ian series 1
You will have to do some Annealing to the wings by the sounds of it?
It's not too bad to do, just don't go past the point of no return... Big Cry
When I did mine, I got an old scrap wing to practise on before I started the originals,
It's a good way of working out what looks and feels right.
Wink 80" 80" 86" 88" 90"
Post #635828 5th Jul 2017 8:11pm
Page 1 of 4 1234>
