Home > My Defender > New Zealand Td5
Page 3 of 3 <123
L110CDL
As said, cracking job Thumbs Up Clayton.
Keeper.
Post #667794 29th Nov 2017 10:22pm
hinsonberger
New Zealand 2003 Defender 110 Td5 XS CSW Zambezi Silver
Out on Christmas Day with the boy enjoying the hot weather, and our presents:
My Christmas present a bit closer up Thumbs Up
Post #673356 25th Dec 2017 7:23pm
L110CDL
Very nice present you got there Wink Clayton.
Keeper.
Post #673691 27th Dec 2017 11:00pm
hinsonberger
Small job fitting the towing socket into it's correct home Wink
Nice to get little things sorted.
Post #675015 1st Jan 2018 8:30pm
hinsonberger
Cubby Box Install
Whilst nice (but not often utilised) to have 10 seats, I had always intended to remove the front row middle seat & replace it with a cubby box. I didn't want to spend too much, so decided to go for a Britpart one. With our Defender having the XS interior, I considered whether to go with an XS trim box, or a plain black vinyl one. I scoured the net for images & found a few, & made a decision to go with the plain vinyl one. Just a personal preference on what I thought looked best really!
The middle row seat came out fairly easily, although the access to the bolts at the rear where a little restricted, plus I had to get assistance from the wife holding the bolted while I undid the nuts from beneath the vehicle.
There where rivnuts installed in the centre cover plate under the seat, which I used to mount the cubby box. After rechecking measurements several times, I drilled the base of the cubby box as well as cutting & painting some wooden blocks to lift the box to the correct height & bolted it in with some 75mm long bolts.
I did have a bit of a challenge removing the cupholder (as that's where the front bolts needed to go through the base), as it is glued in, but after some advice on here; I used a wide scraper with some sustained pressure to lever it out. I also didn't bother to glue it back in as I figured being able to remove it for cleaning might be useful.
I also wanted some cupholders for the kids in the middle row seats, so bought some inexpensive folding cupholders & screwed them to the rear of the cubby box.
Overall I'm happy with how it turned out & it's very nice having a place to put the coffee cup, plus all the other bits & pieces you end up carrying around.
Post #682833 30th Jan 2018 10:02am
hinsonberger
Life Hammers
Installed two original Life Hammers:
Also; I’m sure the heater/blower is stronger since installing the snow cowl. It definitely blows cooler air than it used to, which is a nice added benefit Wink
Post #684436 5th Feb 2018 11:57pm
mk1collector
Top job Thumbs Up if you wanted a nice cubby lid exmoor trim sell cushioned ones in a few different trims including xs. Ray
My build thread
Post #684444 6th Feb 2018 1:20am
hinsonberger
Thanks! I'll add it to the list of potential future enhancements, along with all the other priorities I've got on there Wink
Post #684698 7th Feb 2018 4:22am
hinsonberger
Small improvement made today:
Second hand off eBay. Pretty cheap & came from Spain!
A nice improvement that adds a nice improved functionality.
Post #690310 2nd Mar 2018 8:02pm
JOW240725
Great work. Thumbs Up James
Instagram @suffolk_rovers
Post #690328 2nd Mar 2018 8:39pm
hinsonberger
Another small job on the driver's & passenger's seatbelts:
Post #695811 24th Mar 2018 4:56am
Page 3 of 3 <123
