Home > Puma (Tdci) > Wires through firewall to Engine bay
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
Where/how is the best way to get wires from the engine bay into the cabbin. Wana run Spots and VHF radio from the dash to the front. I also need to get into the battery box to run Dual battery system .Whets the best way to get in/out there?
Post #58458 11th Feb 2011 1:16pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi,
The easiest way would be down to Chassis member then along it to below battery box. The +tve and -tve from battery come out of the battery box via rubber grommets/holes in the battery box sides. More than enough room to take more cables. Thumbs Up
Post #58478 11th Feb 2011 2:11pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
THere are two large rubber grommets in the engine bay - this is the one on the driver's side:
there's also a similar one on the passenger side but more difficult to get to as it's obscured by the bracket for the heater hoses[/img]
Post #58505 11th Feb 2011 4:29pm
TJ101
As above,, I use the LH (pass) side for my looms etc, can get to it just via the cover in the dash ,, underneather for the winch cables,, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #58506 11th Feb 2011 4:32pm
mse
I use the px side through the bulkhead.
Be warned it's far from an easy access point! But doable Mike
Post #58562 11th Feb 2011 11:09pm
