Home > Puma (Tdci) > Wires through firewall to Engine bay |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Hi,
The easiest way would be down to Chassis member then along it to below battery box. The +tve and -tve from battery come out of the battery box via rubber grommets/holes in the battery box sides. More than enough room to take more cables. |
11th Feb 2011 2:11pm |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 |
THere are two large rubber grommets in the engine bay - this is the one on the driver's side:
Click image to enlarge there's also a similar one on the passenger side but more difficult to get to as it's obscured by the bracket for the heater hoses[/img] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
11th Feb 2011 4:29pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
As above,, I use the LH (pass) side for my looms etc, can get to it just via the cover in the dash ,, underneather for the winch cables,, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Main Brian James Trailer Dealer for South West UK |
11th Feb 2011 4:32pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
I use the px side through the bulkhead.
Be warned it's far from an easy access point! But doable Mike |
11th Feb 2011 11:09pm |
