Home > Puma (Tdci) > Lumpy idle
Page 3 of 4 <1234>
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
dgardel wrote:
I meant only for the PCV learning process. Pilot learning MUST be done with the remap loaded
I did Pilot learning with the BAS remap installed. After around 10.000 miles I got 4 fault codes saying that injector learning on each injector had not been completed. Tick over was lumpy and rough. Checked the FAQ part of BAS website and found that Pilot learning should only be done on the standard map. Reinstalled standard map, did procedure, reinstalled BAS remap.
Engine sweet at tickover and no fault codes.
Here's a link -
https://bellautoservices.co.uk/help-faq/ba...4tdci/vcv/ Just because you're offended doesn't mean you're right.
Post #645650 22nd Aug 2017 12:16pm
Naks
thanks mate, but I'm confused now: two people telling me to do the exact opposite Rolling with laughter
but it's worth a try, will do this after work when then engine has been warmed up on my drive home.
It's just a PITA, since my remap is still on the old BAS interface and not the IID, hard to justify the new expense of getting the remap again... --
Post #645652 22nd Aug 2017 12:20pm
shropshiredefender
Understand your confusion - why not contact Pete Bell (BAS) for the definitive answer? I've found his response time to be almost instant if you use the BAS website Thumbs Up Just because you're offended doesn't mean you're right.
Post #645666 22nd Aug 2017 1:53pm
Jonnyfive
England 2011 Defender 90 Puma 2.4 X-Tech LE Zambezi Silver
Try a different fuel station for a few tanks, I had a rough idle after I bought fuel from a different garage, didn't go back there again. No jumping needle since.
Post #645705 22nd Aug 2017 5:51pm
Naks
Thanks Jonny, I have put in 3 tanks from different stations since this started, no change.
I have also reverted back to the factory map, and re-did the pump & pilot re-learn, and it was actually worse this morning! Shocked
let's assume it's one or more injectors - what readings can I take with my IID tool to confirm/deny this?
Thanks! --
Post #645807 23rd Aug 2017 6:43am
shropshiredefender
Sorry to hear that.
Just a thought, I've swapped maps several times and each time it seems to take a few trips before everything settles down. The map seems to need a few "driving cycles" to get everything working properly. Bit of a long shot but may be worth a try.
Post #645857 23rd Aug 2017 11:45am
Naks
thanks, will leave it on the factory map for a few days and see.
Funnily, I swear I couldn't tell the difference between the two maps when I drove this morning.
And yet, I do recall how different the truck felt when I had to swap the maps for the services at the dealership. --
Post #645871 23rd Aug 2017 1:32pm
Naks
I have contacted BAS, who kindly offered to send me LR software updates prior to switching my remap from the old interface to the IID tool.
top service Thumbs Up --
Post #645876 23rd Aug 2017 1:53pm
shropshiredefender
Pete gives a service that is truly above and beyond Thumbs Up Just because you're offended doesn't mean you're right.
Post #645915 23rd Aug 2017 4:48pm
Naks
Went to my mechanic yesterday, we checked over a few things.
The diagnosis is injectors are on their way out... but I'm running a tank on Wurth Diesel Cleaner first in case it was just bad diesel clogging the injector tips.
If not, R22k bill for 4 injectors. So much for buying the new Oppo 205 Big Cry --
Post #646056 24th Aug 2017 10:21am
shropshiredefender
Ouch - around £1300.00 Sad Just because you're offended doesn't mean you're right.
Post #646060 24th Aug 2017 11:20am
Naks
can anyone tell me if those readings look normal?
1. Cold Start
2. Warmed up at 80kmh
Post #646252 25th Aug 2017 11:26am
Naks
chaps, I ran a scan yesterday and the following came up, but will not clear + the dates are completely wrong.
What is going on here?
Quote:
Model L316 - Defender 2010
Vehicle scanned on 25 Aug 2017 18:37:02
IIDControl 2.9.4.5 Android - IIDTool BT V3.0 B2272
PCM-Engine Puma 2.4
P1935-14 (10) Brake switch/sensor signal - General electrical failure - circuit short to ground or open
( on 03-09-2017 01:26:55 at 0 km )
*Test Not Completed
P0404-73 (10) Exhaust gas recirculation control - circuit range/performance - Mechanical failure - actuator is stuck closed
*Test Not Completed
P02A8-00 (10) Cylinder 4 balance - injector restricted
*Test Not Completed
P02A0-00 (10) Cylinder 2 balance - injector restricted
*Test Not Completed
P0606-49 (10) Engine control module/powertrain control module processor - System internal failure - internal electronic failure
*Test Not Completed
P029C-00 (10) Cylinder 1 balance - injector restricted
*Test Not Completed
P02A4-00 (10) Cylinder 3 balance - injector restricted
*Test Not Completed
Post #646519 27th Aug 2017 6:59am
Naks
anyone? Whistle --
Post #646737 28th Aug 2017 9:40am
Naks
Can anyone tell me whether a fuel rail temperature of 26C is normal at cold startsup when the ambient temperature is around 10C?
thanks --
Post #647563 1st Sep 2017 6:26am
Page 3 of 4 <1234>
