Home > Puma (Tdci) > Rear work light wiring
GN
I have been looking through the LR TOPIx owner instructions trying to find the one for wiring a rear work light. Can't seem to find any reference- does any have the instruction or diagrams?
Post #58228 10th Feb 2011 10:25am
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
Do a search. There was a topic on a black and purple wire behinf the rear right speaker panel. Already fused. I'm gonna use this wire for the rear work light.
Post #58240 10th Feb 2011 11:29am
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
would fuse it down further though to 7.5 amps
Post #58323 10th Feb 2011 5:44pm
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
If you use the wires behind the speaker where will the switch be?
Post #58334 10th Feb 2011 6:36pm
Marius
Use a relay located at the back with only the switch wires going to the front
Post #58359 10th Feb 2011 8:36pm
defender75
Would love to see a picture of the setup
Post #58362 10th Feb 2011 8:49pm
Marius
Not sure how to upload drawings..... here goes explanation.
Use a standard Automotive relay.
- Pin 87 goes to the black wire (ground)
- Pin 85 Goes via a 7.5A fure to the purple wire (12V)
- Pin 86 goes to the rear working light and from there gets grounded to the Chassis (Not sure if one can also use the black wire to ground with?)
- Pin 30 goes to the on/off switch in the dash and from there to a 12V source
If This looks incorrect please rectify me.... Rolling Eyes
Post #58408 11th Feb 2011 8:14am
BruceT
South Africa
Installed mine yesturday. My work light has a hidden switch on it and I have converted it with an LED globe.
I connected straight to the purple and black wires and it works perfectly. I did not bother with a dash board switch and the light uses so little power when its turned on I could not get a reading on the amount of amps it draws.
Post #58762 13th Feb 2011 9:00am
defender75
where did you mount it?
Post #58828 13th Feb 2011 3:58pm
Marius
Great stuff. I myself would prefer the switch to sit at the back. Soppose one could connect a dual switch. Back and front.
Post #58925 13th Feb 2011 9:26pm
PaulMc
That's how I've wired my rear worklamps, so that they can be switched on/off from either the dash or from a switch inside the back door -
The relay lives inside the R/H rear lamp cover and uses the existing Purple wire to supply the work lamps.
The down-side is that you have to run 3 wires from the front to the back - 2 switch lines and one for the warning lamp in the dash switch.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #58953 14th Feb 2011 1:35am
BruceT
South Africa
I mounted it to the back of the roof rack. Here is a picture of it mounted and not hooked up.
http://www.flickr.com/photos/9885024@N05/5099774428/
Sorry I dont know how to add pictures to the forum.
Post #59025 14th Feb 2011 3:06pm
defender75
where did you run the wire?
Post #59062 14th Feb 2011 6:03pm
BruceT
South Africa
I ran it from the roof rack to the gas bottle holder, then under the roof gutter to the door, pulled away the rubber and at the top of the door is a hole (that was there from the factory) which I threaded the cable through, then down the inside of the panel to behind the speaker.
I hope this makes sense.
Post #59161 15th Feb 2011 4:54am
Merlin
I fitted mine to the left hand side (viewed from the rear), as that way you don't get a shadow when the back door is open. The wires go throught the panel and down to the wires behind the speaker. You can see it, or not, in the picture below. The aerial has picked up some vegitation and that's where the light is:
[url]
That's the wife opening a gate on a greenlane, bless her. No need for a shower today then.
The light also comes on when reverse is selected. I'll send a wiring diagram if you are interested.
Merlin[/url]
Post #59230 15th Feb 2011 4:24pm
