Home > Camping, Caravanning and Holidays > Can anyone translate german
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Morning,
Can anyone translate this trailer data plate, for reference its a twin axle box trailer.
I'm trying to understand what its tare weight is and hence capacity as I'm guessing that the 2700kg is the gross weight.
Thanks
Keith Keith
Post #624520 16th May 2017 7:22am
grafty99
Zul. Is an abbreviation of zulässige which means permissible so
Zul. Stützlast is the maximum nose weight
Zul. Gesamtmasse is maximum gross weight.
Bis means to. So the literal translation is max gross weight 1400 to
2700kg
Which isn't much help I suppose Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #624533 16th May 2017 8:22am
grafty99
I can't imagine a box trailer weighing 1400kg empty however. If that is the case though it has a 1300kg capacity.
Unless that is the actual hitch rating. I'm which case the loading data will be another plate on the trailer. 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #624534 16th May 2017 8:29am
grafty99
Ah just spotted Auflaufeinrichtung at the top of the plate. This is overrun hitch type. So this is the hitch plate with the maximum loading of the hitch itself not the trailer Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #624535 16th May 2017 8:30am
Keith5
That's more than I understood when I posted.
I did wonder if the 1400kg was tare and 2700kg was gross, however 1400kg seemed to be heavy for an empty trailer. Keith
Post #624536 16th May 2017 8:31am
grafty99
Yes 1400kg is a bit heavy for an empty box trailer! This is the hitch rating and not the trailer itself. I just googled the hitch code and it's a Knott hitch so there should be another plate on the trailer giving the actual trailer weights Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #624539 16th May 2017 8:41am
Swine&Small
Hi. If you type in a sentence into google it can translate for you. Just start by entering German to English. 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #624554 16th May 2017 10:02am
miker
You can just take a photo using the translate app and it will do the rest!
Post #624647 16th May 2017 4:40pm
Keith5
I've found the trailer plate rather than the overun hitch plate now.
My understanding is that the empty trailer weight is 1350kg and the gross weight would be 2700kg. Seems to be consistent with the hitch rating.
If I've misunderstood any of this then please feel free to correct me.
Thanks Keith
Post #624797 17th May 2017 10:08am
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
It would be the permitted axle loading's, 1350 kg's per axle, giving a gross axle weight of 2700 kg's NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #624799 17th May 2017 10:23am
Keith5
Is there a way to find the tare weight then?
I understood that this should be stamped on the trailer plate as well.
Thanks Keith
Post #624800 17th May 2017 10:26am
NormanD
It's an Ifor Williams BV85G Twin Axle Box Trailer, go to their web site and look at the specificaio of your trailer, should be easy, try here - http://www.iwt.co.uk/products/box-van/box-...chures#tab NormanD WE191
2015 110 XS Utility
Post #624801 17th May 2017 10:33am
NormanD
Did you manage to resolve your questions? NormanD WE191
2015 110 XS Utility
Post #625068 18th May 2017 10:57am
Keith5
I think I should be good, going to measure the trailer tonight and compare to the dimensions in you link.
Thanks
Keith Keith
Post #625073 18th May 2017 11:06am
Thanks
If all else fails, take it to a public weighbridge.
Post #625075 18th May 2017 11:11am
