![]() | Home > Camping, Caravanning and Holidays > Can anyone translate german |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
Zul. Is an abbreviation of zulässige which means permissible so
Zul. Stützlast is the maximum nose weight Zul. Gesamtmasse is maximum gross weight. Bis means to. So the literal translation is max gross weight 1400 to 2700kg Which isn't much help I suppose ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
I can't imagine a box trailer weighing 1400kg empty however. If that is the case though it has a 1300kg capacity.
Unless that is the actual hitch rating. I'm which case the loading data will be another plate on the trailer. 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Ah just spotted Auflaufeinrichtung at the top of the plate. This is overrun hitch type. So this is the hitch plate with the maximum loading of the hitch itself not the trailer
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 357 ![]() ![]() ![]() |
That's more than I understood when I posted.
I did wonder if the 1400kg was tare and 2700kg was gross, however 1400kg seemed to be heavy for an empty trailer. Keith |
Yes 1400kg is a bit heavy for an empty box trailer! This is the hitch rating and not the trailer itself. I just googled the hitch code and it's a Knott hitch so there should be another plate on the trailer giving the actual trailer weights
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 ![]() ![]() |
Hi. If you type in a sentence into google it can translate for you. Just start by entering German to English. 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
You can just take a photo using the translate app and it will do the rest!
I've found the trailer plate rather than the overun hitch plate now.
![]() Click image to enlarge My understanding is that the empty trailer weight is 1350kg and the gross weight would be 2700kg. Seems to be consistent with the hitch rating. If I've misunderstood any of this then please feel free to correct me. Thanks Keith |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
It would be the permitted axle loading's, 1350 kg's per axle, giving a gross axle weight of 2700 kg's NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
Is there a way to find the tare weight then?
I understood that this should be stamped on the trailer plate as well. Thanks Keith |
It's an Ifor Williams BV85G Twin Axle Box Trailer, go to their web site and look at the specificaio of your trailer, should be easy, try here - http://www.iwt.co.uk/products/box-van/box-...chures#tab NormanD WE191
Did you manage to resolve your questions? NormanD WE191
I think I should be good, going to measure the trailer tonight and compare to the dimensions in you link.
Thanks Keith Keith |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17725 ![]() ![]() ![]() |
If all else fails, take it to a public weighbridge. |
