Home > Off Topic > My RRC project |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4792 |
2002 90 Td5 Station Wagon
30th Jan 2018 8:22am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Good to see it taking shape,
What is the shell like, has it still got all it’s door pillars and sills? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
30th Jan 2018 9:25am |
Been a while since I checked in on this, wow Grafty it’s really taking shape 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
30th Jan 2018 9:30am |
Thanks chaps. The shell is all original inc boot floor. Inner sills are good, outer sills will be replaced.
The main work will be the front end as the inner wings are shot to pieces. Once the sills are sorted the plan is to cut off the front end and get the body on the chassis. That will then allow me to line up the new front end with the chassis and get it all welded on. Then it's just a case of sorting th body panels which are pretty good 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
30th Jan 2018 12:19pm |
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 |
Just read all 16 pages keep up the excellent work .Back in the day I had a couple of classic Range Rovers first one was a Turbo D and next one had the Mazda 3 litre diesel fitted,I only had one petrol a 3.5 on carbs could not keep up with it's drinking habit.
Click image to enlarge My Mazda 3 litre Range Rover towing a Jaguar that needed well lots of work. |
30th Jan 2018 9:52pm |
LOOOONNNGGG overdue update on the range rover.
The underside has been primed and undersealed ready for the body to be mounted back onto the chassis. Will be rolling again soon Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
9th Mar 2018 7:54pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10844 |
Much better i think the late update is due to the Tea and biscuits consumed Clayton.
1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
9th Mar 2018 8:11pm |
9th Mar 2018 8:25pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6771 |
Never mind tea and biscuits you haven't time for those, I've been having withdrawal symptoms with no updates Ray
9th Mar 2018 8:48pm |
Not to worry Ray, things should be moving on slightly quicker now 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
9th Mar 2018 8:54pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5216 |
yeah not to mention the dodgy dealings too Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
11th Mar 2018 9:05pm |
was there much to repair underneath? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
11th Mar 2018 9:06pm |
Not really no. I replaced the bottom 25mm or so of inner sill, mostly as a prevention as it would probably have needed doing in the next couple of years or so. The rest is solid. Inner wings, outer sills and then it just cosmetic bits really 2002 90 Td5 Station Wagon
11th Mar 2018 9:16pm |
good stuff there grafty! Are you going to seam seal under too? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
11th Mar 2018 9:33pm |
