Home > Maintenance & Modifications > transfer case leak defender puma |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1800 |
Check carefully where its coming from,
1) input seal into transfer box from gearbox - transfer box out 2) intermediate shaft seal on transfer box - lower than above - transfer box nearly out 3) front or rear output seal to propshafts - pretty easy Clean it ll up well, take for a drive and check where it's coming from |
9th May 2017 7:12pm |
Tim seymour Member Since: 17 Jan 2010 Location: Devonport TAS Posts: 92 |
Thanks Ickle Cess the Taswegian
9th May 2017 10:44pm |
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 |
9 x out of 10 it will be 2 as mentioned above.
9th May 2017 11:28pm |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
Out of the three vehicles with a LT230 l have had, they have all leaked from the intermediate shaft at about 100K Kms.👍 Quite reliably 😂👍
10th May 2017 1:50am |
ok mine has done 97k so the money cheers Cess the Taswegian
10th May 2017 3:13am |
