Home > Maintenance & Modifications > transfer case leak defender puma
Tim seymour
Australia
Hi I have an oil leak between the transfer case and the front output shaft is this a big job and what is involved cheers Tim Sad Cess the Taswegian
Post #622794 9th May 2017 12:14am
ickle
Check carefully where its coming from,
1) input seal into transfer box from gearbox - transfer box out
2) intermediate shaft seal on transfer box - lower than above - transfer box nearly out
3) front or rear output seal to propshafts - pretty easy
Clean it ll up well, take for a drive and check where it's coming from
Post #622971 9th May 2017 7:12pm
Tim seymour
Australia
Thanks Ickle Smile Cess the Taswegian
Post #623042 9th May 2017 10:44pm
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
9 x out of 10 it will be 2 as mentioned above.
Post #623048 9th May 2017 11:28pm
pannawonica
Australia
Out of the three vehicles with a LT230 l have had, they have all leaked from the intermediate shaft at about 100K Kms.👍 Quite reliably 😂👍
Post #623052 10th May 2017 1:50am
Tim seymour
Australia
ok mine has done 97k so the money cheers Sad Cess the Taswegian
Post #623054 10th May 2017 3:13am
