Home > Puma (Tdci) > Rust on random bits |
Nearly did Mike! You know me!!! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
7th Feb 2011 9:19pm |
defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219 |
knew that was coming |
7th Feb 2011 10:04pm |
At least using 800°C resistant paint Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
7th Feb 2011 10:28pm |
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
7th Feb 2011 10:29pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5034 |
Mike |
7th Feb 2011 11:20pm |
I heard painting in red made the car go faster...is that also true Mike |
8th Feb 2011 9:32am |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
Only safe to do that if you uprate the braking system by painting the calipers red so you can stop better too .. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
8th Feb 2011 10:56am |
got you Mike |
8th Feb 2011 5:46pm |
