![]() | Home > Australia & New Zealand > Roof rack flooring? |
JimmyLR Member Since: 03 Nov 2010 Location: Cornubia Posts: 19 ![]() ![]() |
G'day,
i was thinking about the same thing should I require a solid floor to sit in the rack. I've seen a piece of ply used quite effectively as its light and strong and readily available. I have some marine ply out of an old rubber ducky boat that fits together in sections that I will use when I need it for trips. Cheers |
tt3 Member Since: 01 Feb 2011 Location: Auckland Posts: 5 ![]() ![]() |
Thanks for the reply JimmyLR! Defender 110 2011
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
Hi guys, these racks are made by safety devices and on their website in the uk they mention they do a flooring kit.
Might be worth seeing if they have a distributor in your neck of the world. You cannot teach stupid people to do clever things |
Josh_WA Member Since: 24 Aug 2010 Location: Perth, W.A. Posts: 9 ![]() ![]() ![]() |
i have seen guys use form ply ( the black stuff) to good effect. its a bit stronger for standing on or heavier loads but is an abosolute
![]() there have also been reports that this mod can reduce the heat build up in the cabin by partly shading the roof. Cheers ________________________ Josh 2006 Defender 110 Double Cab |
Thanks Josh_WA, i've been doing some research my self and have identified another couple of options that may be suitable. I received this from a sign company; "Yes, the ACM (aluminium/pvc composite) we use would be excellent for your roof rack.
The standard sheet size is 1220mm x 2440mm and is 4mm thick, available in blk,silver, white for NZ$140+gst There are other colours available, blue, red, yellow and orange but these are only available in 3mm thickness and are the same price". Apparently its quite strong. Also a product called HDPE (similar to chopping board plastic has been recommended to me and comes in larger sheets, http://www.dotmar.co.nz/polystone-300/poly...eets.html. This is available in 3mm and 5mm+ options. I will inspect both options and measure them up. Cheers Defender 110 2011 |
Red Desert Member Since: 23 Aug 2010 Location: Lake Constance Posts: 53 ![]() ![]() |
separate fields made of 2.5mm AL would be a nice and strong solution :
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
The standard fitment to the Land Rover racks was a ply material called Buffalo Board. A Google search will give you more info. 130's have feeling's as well you know
Thanks for all your suggestions. I get the roof rack and defender to attach it to in 4 weeks so will report back after that. Defender 110 2011
v40mav Member Since: 25 Aug 2008 Location: UK Posts: 206 ![]() ![]() |
Guys - I've just bought and fitted the LR expedition rack to the 110 - What flooring is recommended for this and how best to fit the floor to the tubular rack -
I recall seeing some pics in a post but cannot find link anymore - any pics welcome Cheers Defender 110 County SW Disco 3 HSE Freelander 2 HSE - SOLD going back to a car www.lothian4x4response.org |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
I'm thinking of getting some Buffalo board for sections of the Brownchurch (but not all of it). Pics of LR set ups:
![]() Click image to enlarge ![]() Click image to enlarge |
