Home > Wheels & Tyres > How long should tread last?
ukmiitchellx
I know this is a question which is hard to answer but how long/how many miles should 5mm of tread last? I don't want to buy some tyres 2nd hand only to have to change then again after 6 months! I know there's loads of variables but a rough estimate? Thanks! 1995 300TDi Hardtop Nato Green
Post #622148 6th May 2017 3:33pm
Depends on what tread bias type you are talking about? Road, 50/50 ATR or MT? No Guts, No Glory.
Post #622150 6th May 2017 3:53pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
There is a lot more to buying second hand tyres than tread wear. You need to know how old they are (tyres degrade over time). How they have been used or abused (if they are fitted to a wheel you have no way of knowing the internal condition).
You should also check for uneven wear, splits and cuts etc.
Can prove to be a false economy compared to known brand retreads or new tryes.
Post #622156 6th May 2017 4:12pm
ukmiitchellx
I was looking at general grabbers if that helps! 1995 300TDi Hardtop Nato Green
Post #622159 6th May 2017 4:19pm
12k maybe, I'd like to see more tread though than that myself. They won't last you long really, No Guts, No Glory.
Post #622160 6th May 2017 4:29pm
I'd have taken them off long before they got down to 5mm and disposed of them!
Post #622164 6th May 2017 4:43pm
ericvv
5mm thread on a 4x4 tire like a GG, Cooper or BFG tire. That's about as far as you want to take it I think and they are ready to be scrapped then. No way you want to keep using those tires down to the 1.6mm legal thread depth minimum. Just imagine that kind of 4x4 tires which are starting new at around 13mm thread depth, how much they have been used and abused while loosing those 8mm.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #622167 6th May 2017 4:48pm
ukmiitchellx
Cheers for the advise and replies guys! It looks like I'll invest in some new ones when needed! Thumbs Up 1995 300TDi Hardtop Nato Green
Post #622171 6th May 2017 5:02pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
Re-tread carcase can be up to 7 years old
Post #622174 6th May 2017 5:22pm
