Home > In Car Electronics > Duel battery install |
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 |
4th May 2017 8:38pm |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
I made something fairly basic to clamp my two batteries in. I can't remember exactly what I did but it wasn't very complicated.
I can confirm that you can fit two standard (019) sized batteries in, but you do need to have a bit of a wiggle around. I have a feeling I've used some bits of 1/2" ply to do the base, then picked up the standard mounts with some threaded rod and put a bar across the pair to clamp them down. |
8th May 2017 8:21pm |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 |
Thank you for the replays.
Fitted the blue sea system this afternoon just need to hook up the battery. Going to use a small standard battery I have in the shed for now and look at a new bigger duel type after payday. Not sure if to splash out on a odyssey yellow top or just a cheaper one, the yellow top has better cca than most cheaper ones and intend to put a set of jump leads off it. The relay was supplied with a small fused earth wire however not sure where to put this as it has a extreamly small eye on so can't think of a easy solution. |
13th May 2017 7:05pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1768 |
Unusual for an earth wire to be fused, definitely an earth? Can either cut off the crimp and put a bigger ring crimp in it, or drill a hole in the battery box and attach it.
14th May 2017 5:28pm |
I thought the same but double checked it is packed as 'pre made earth' Have earthed it to the box.
Just need to get the second battery and connect up the fuse box. Did get the blue sea terminal fuse box however not sure if I have the height to fit so may just fit a proper one |
14th May 2017 6:52pm |
