Home > Maintenance & Modifications > Roof rack / garage / tight
Huttopia
I'm keen on the Hannibal rack that incorporates the pull out table. The rack comes in a natural finish which I hope will fit with the style of the Heritage. The only challenge is that with the rail it adds 6.5in to the height, and the gap between roof and garage door is 7in. That all feels a bit tight and with LR tolerances it could clash. Any views on how precisely the Hannibal racks are built?
Thanks
Post #615716 10th Apr 2017 6:44am
YOLO110
Australia
1/2 inch is PLENTY!
I only have 1cm to play with with my Patriot rack!
I had to adjust the garage door a bit... but it was easily done and worth it! Thumbs Up YOLO... You Only Live Once...
Post #616041 11th Apr 2017 1:04pm
Huttopia
That is brave! I can't adjust the door frame / door without silly expense. I need to try before i buy, could be tricky!
Post #616099 11th Apr 2017 5:45pm
Stacey007
I'm hoping my SIII fits in the garage I've been getting ready for...
I tried my 110 (without rack and it was close... but close is fine if it fits Smile
I changed the up and over door for barn type doors, is this an option or is the height 'the height'.
Good luck. Thumbs Up
Post #616100 11th Apr 2017 5:57pm
Huttopia
That is snug. I've got barn type doors, not standard, made to measure etc. When we built the garage I did not envisage ever putting a Defender in it, let alone one with a roof rack. Production ends, they make a garage queen and look what happens. The 96 pick up is left out to fend for itself.....
Post #616102 11th Apr 2017 6:04pm
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
Don't forget, depending on the weight of the rack, it'll sink your suspension a little bit all round, not by much, but it'll offset the height increase a smidgen. North Cumbria Search and Rescue - Team Leader
Post #616179 11th Apr 2017 9:45pm
flydive
Switzerland 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
Can you lower the garage floor?
Post #616211 12th Apr 2017 7:28am
AJC
Mine is about 4 inch shy of fitting in the garage, I should of bought the defender and then built the garage. Not the other way round!
Post #616215 12th Apr 2017 7:39am
Avion8
Australia 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
A recent problem I also had as the new house garage has only 1.9mtrs clearance with the panel lift door. So had to build a new Defender shed! Big Cry
We now have 2.35mtrs of clearance & no lawn!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  1955 Series 1 107" Pick up.
1977 RRC Suffix 'D'.
2000 Defender 110 TD5 Xtreme.
2015 Defender Heritage 90.
Post #616249 12th Apr 2017 9:37am
thats not Big Cry ....it's Cool
Post #616272 12th Apr 2017 11:09am
L110CDL
^ ^ ^ +1 Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #616411 12th Apr 2017 8:58pm
BigRuss
If it fits in it's fine but will you have it on all the time? I have enough space in the garage roof so I can string it up and leave it there and still get in and out of the garage with the defender. Russell
2011MY 110 XS USW Black
Post #616418 12th Apr 2017 9:17pm
Huttopia
Good point, I could take it on and off but it feels like a ball ache. I can't drop the floor either. I'm going to see if I can get a mate with a frontrunner to test it.
Post #616426 12th Apr 2017 9:32pm
Sulisuli
Instead of reducing the whole floor level have you considered cutting and reducing two strips that the tyres would fit into? You could cut them 300mm wide and 50mm deep perhaps? If you want more information on a way to do this feel free to message me. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #616429 12th Apr 2017 9:38pm
Harry.O
Can you not fit the rack without the surrounding rail? That should give you 3-4 inches of clearance between the rack and the garage door. The table looks like it hangs below the rack so shouldn't have an effect on the overall height.
I have a Hannibal rack without rail side rails, happy to take some measurements if that helps Very Happy
Post #616443 12th Apr 2017 10:17pm
