![]() | Home > Technical > Does this transfer box fit a Td5? |
Williamraff Member Since: 19 Mar 2017 Location: Leeds Posts: 40 ![]() ![]() ![]() |
Hi folks,
Can anyone advise whether this Discovery / Range Rover transfer box will fit my 2006 Td5 Defender; ebay item number - eBay Item No. 292076582842 I was hoping to recondition this and fit a disc hand brake conversion before removing my existing transfer box. Many thanks, Will. |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
It's from 1992 not 1976 - date marker is upside down in the last photo
psimpson7 Member Since: 20 Nov 2013 Location: Gold Coast, Qld. Posts: 221 ![]() ![]() ![]() |
![]() 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
I have removed my bid on the basis of the info above - are we now saying that it is not a duffer or should I leave well alone?
Thanks, Will. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17600 ![]() ![]() ![]() |
Looking at the state of it, I wouldn't touch it with a bargepole. Cheap doesn't necessarily mean good value.
True enough, I will probably leave it and recondition my own if / when I need to do the clutch.
Yeah I wouldn't touch it still. 92 is still quite early and it doesn't look cared for,
Surely you can find someone breaking a late d1 which would be a far better place to start. 2001 90 HT 6.0LS/6spdAuto. 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
