Home > Td5 > Manifold de-webbing
Page 2 of 2 <12
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Geobloke, I'm interested in the Alisport manifold as I too have a VNT Turbo, is the any noticeable difference between the old design manifold and this one?
Cheers Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #615809 10th Apr 2017 4:00pm
geobloke
CDN38 wrote:
Thanks for the pics geobloke! Yes, I really MUST get one of these manifolds. Interesting design, how the manifold stands further off the head, longer individual header tubes and a shorter collector where they all meet. Do you run the standard (or any)heat shield over top?
Yes bog standard heat shield.
Post #615827 10th Apr 2017 5:23pm
geobloke
Cheers Will
Hi Will. I have a standard albeit new Garrett turbo. Hybrid would be the next step up. The difference of a standard turbo, full sized inter cooler, manifold and remap (generic so not tuned to my engine - defo need this next) is remarkable. The exhaust note seems a little sweeter ESP mid range. Low Rams are dogged by over fuelling hence the need for a retune. Once retuned I am hoping for great things.
Physically speaking the differences are as CDN38 says longer header tubes and a shorter coolector. The important thing is that it is a straight swap incl. standard gaskets.
I personally fitted this manifold for peace of mind and longevity. The Miffster is a keeper and will be our stead for many many years to come. Thumbs Up
Post #615830 10th Apr 2017 5:30pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Geobloke, I am in the throws of putting this set up on a friends truck. The Allisport exhaust manifold, and a VNT turbo. One thing I see first off is there is almost no room between the top of the centrifuge filter and the manifold, as well as the turbo. How do you get the filter cap off for filter changes? Certainly you shouldn't need to remove the turbo to do it, but it is really that tight! Not to mention one of the bolts for the cover is obscured by the manifold.
 it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #641270 1st Aug 2017 9:24pm
lightning
Mine was remapped by Alive but it produced too much smoke. I had to get it reset at Land Rover after being stopped by the Police and given a VRN. (vehicle rectification notice, giving me 7 days to fix it)
I since got it remapped by Mike at Dynachip and after some adjustments it's perfect. More performance (although not as much as the Alive remap) but without the smoke screen l had after Alive did it.
However l don't think Dynachip do postal remaps, so no good if you are not in the UK.
Post #642100 5th Aug 2017 8:33pm
mk1collector
I thought you got yours remapped buy an alive agent, not alive themselves? Ray
My build thread
Post #642198 6th Aug 2017 10:21am
Page 2 of 2 <12
