Home > Maintenance & Modifications > Any experience with SP 4x4? (doors)
BCdefender
Canada 1999 Defender 110 Td5 CSW Orkney Grey
Just wondering if anyone has had experience with SP 4x4. I am considering getting one of these galvanised rear doors for my 1999 110. The major advantage is that everything will swap over whereas with a puma door I have to start from stratch ie new window, electrics trim etc.... Not too sure about the big difference between these two but the idea is the same:
(Thanks to Intercept for the lead!)
https://www.sp-4x4.com/DEFENDER_90_110_GEN.../ajc6g.htm
Vs
https://www.sp-4x4.com/DEFENDER_GALVANISED...-steel.htm 1999 Defender 110
2003 P38
2007 RR SC
"And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it."
My build thread: http://www.defender2.net/forum/topic47750.html
Post #613192 30th Mar 2017 1:46am
I've used SP for the doors for my 90 build, they're absolutely fine. No experience with a rear door though.
Post #613198 30th Mar 2017 5:45am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I've had some series 3 door tops from them and they are very good.
Like Greeni I can't vouch for their rear doors, but their parts seem to be good quality and finished well,
Also their service is spot on. Wink 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #613201 30th Mar 2017 6:11am
Jim G
United Kingdom 1984 Defender 90 300 Tdi HT Stornoway Grey
I had aluminium front and rear ( single 90 door) door skins from them. Excellent fit and 2 years on still good ! 1984 300TDi hardtop Stornoway Grey
1984 200TDi hardtop..... soon to be a V8 .. but which V8 ?
1974 DAF T244 4x4 wagon converted to a motorhome
1976 Jaguar XJC with supercharged engine
Post #613205 30th Mar 2017 6:55am
BigRuss
I bought a rear door off then the other year, the first one was dropped by the courier and they were quick to offer a discount or replacement. I'd have no issues ordering from them again. Russell
2011MY 110 XS USW Black
Post #613207 30th Mar 2017 7:00am
VVS210
Re: Any experience with SP 4x4? (doors)
Vs
The top one is a galvanised frame with an aluminium skin, still a potential for galvanic reaction (corrosion in the aluminium) so I'd go with the bottom one which is galvanised frame & zinc plated skin so little if any risk of corrosion caused by dissimilar metals.
Post #613208 30th Mar 2017 7:02am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
You're welcome. I was torn on the choice between aluminium or steel skin for my 4 new side doors - they are the same price. I decided to go for steel and I'm very happy with the result. Hopefully I'll be equally happy in 10 years time...
John
Post #613263 30th Mar 2017 11:41am
selectcase
United Kingdom 1998 Defender 110 300 Tdi CSW Alaska White
SP - very poor service
HI
i just thought i should advise members here of the extremely poor service i have received from SP panels - I ordered 2 door skins from the website, no receipt sent, late delivery, poorly packed and delivered to the wrong address 1/2 mile away - panels were bent and damaged and they took a week to reply to my return request via paypal and I have to pay upfront for the return. also no reply to any emails sent direct to them. This is the worst service I have ever received from any supplier and is a factual account. Plus the panels are zintec coated and not galvanised as advertised. Please be aware and avoid this company because if the goods get damaged there is very little in terms of customer service.
Post #788325 22nd Aug 2019 8:37pm
MT
I too had problems with SP. The skins were very badly crimped to the frames and the body shop took days (£££) to get it to look acceptable.
What ever the coating may be it has started to corrode after 4-5 years of being fitted. I do accept that the paint job has a major part to play in this though.
Post #788328 22nd Aug 2019 8:51pm
Money well spent then MT Rolling with laughter
Post #788344 22nd Aug 2019 10:04pm
MT
That's my thoughts precisely. Frustratingly its due to have all the 5 "new" doors repainted soon. I'm always a little conscious that its a down hill battle once corrosion has started...
Post #788347 22nd Aug 2019 10:30pm
Litch
I have also had very poor service from SP 4x4 and cannot recommend them.
I ordered a pair of their all steel front-doors a few months ago and the service was awful (full run down is too long to go into).
One of the doors (which although ordered at the same time arrived 2-weeks apart with no notice of dispatch) had been manufactured incorrectly and the messages I received when requesting replacement were that the doors CANNOT be manufactured wrong as the are hand-made and I was the one who didn't know what I was talking about! The door was sent back and they eventually agreed that it was a manufacturing fault which would be rectified however even this was a halfhearted affair and although the doors are now in the process of being painted ready for fitment I am still not entirely happy.
If you want all steel doors you don't have much choice but I say look elsewhere and consider all options as SP 4x4 do not give anything like satisfactory service, if anything happened to my doors in the future I would certainly NOT be replacing it / them with SP 4x4 items as one bitten, twice shy.
 ONE LIFE, GET IT!
Post #788366 23rd Aug 2019 8:49am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I bought a couple of their S3 doors, they were terrible, welds failing and the hole for the door locks in the wrong place. I eventually got through to them and they took them back and gave me a full refund, I subsequently bought some from Paintman panels which were fine. My son bought some door tops from SP and they were ok.
Post #788405 23rd Aug 2019 7:20pm
Slideywindows
I bought a Defender rear door from SP.
Bottom was warped so sent it back and replaced it with a door from Paintman Panels.
Haven't fitted it yet but it seems OK, so I've just had another delivered from Paintman today. Yet to open the package though.
Had a chat with the man at Paintman, who was willing to discuss how I can convert the latter door to fit early One Ten Station Wagon.
(The rear door sliding stay is a lot lower than on a Defender).
It will be a while before I fit either door (prep, painting, glass and furniture fitting this Autumn, so will report problems if there are any.
Post #788411 23rd Aug 2019 8:00pm
foxhound
United Kingdom 1995 Defender 110 300 Tdi SW Alpine White
"The top one is a galvanised frame with an aluminium skin, still a potential for galvanic reaction (corrosion in the aluminium) so I'd go with the bottom one which is galvanised frame & zinc plated skin so little if any risk of corrosion caused by dissimilar metals."
Doesn't the marine bonding keep the galv frame and ally skin apart? I'd like to avoid steel door skins as they rust when the paint is scratched? 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
Post #790329 3rd Sep 2019 6:54pm
