Home > Puma (Tdci) > optimised air intake?
Page 3 of 5 <12345>
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Thumbs Up 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT“s,
Recaro CS“s, anorak, wellingtons
Post #614148 3rd Apr 2017 7:09am
Likeomg
didnt IRB have something in the pipe line? don't exactly remember the specifics..
Post #614224 3rd Apr 2017 2:38pm
thrasher
Scotland 2007 Defender 90 Puma 2.4 HT Bonatti Grey
again thanks for all the replys.decided to go ahead and make my on air intake from either side vent or wing top vent,im not bothering with the raised air intake or snorkel as I don't intend to go into water that deep!!!!! looking more at the performance side of things,will keep you updated on how I go about it
Post #614559 4th Apr 2017 9:40pm
labrado
Australia 2009 Defender 110 Puma 2.4 SW Fuji White
what are part 5 and 6 for?
Hi all,
I just had a look at the naktanenga optimised air intake for my RHD 2.4 puma, but couldn't figure out why some components are included in the kit.
As per the picture attached,
1. I'm sure component 2 and 3 go to the wingtop;
2. I guess component 7 goes to the air filter box inlet(is it a reducer that bridges the air filter box inlet and part 4 or 1);
3. either component 4 or component 1 connects the wintop to the air filter box.
So what's the purpose of components 5 and 6?
https://photos.app.goo.gl/yUgF2DtPh8BBLgf2A
Thanks
Wei
Post #761302 1st Mar 2019 1:39am
Wild Card 90
I would guess that that picture applies to a LHD kit. 6 is the bodyside intake scoop and 5 is the adaptor that takes the fresh air into the heater/distributor box on the bulkhead. The shorter piece of convoluted tubing is what joins the two. Apart from the wingtop RAI, this looks like the kit installed on my LHD vehicle (see previous pictures). 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #761308 1st Mar 2019 8:08am
labrado
Ah, thank you very much!
Post #761320 1st Mar 2019 9:47am
Minch90
So advice please - is this optimised kit a worthwhile performance addition to a 2.4tdci (no rai) over the standard (with the forum mod)? 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime
S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down
S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround
Post #762878 11th Mar 2019 1:08pm
HardCharger
I tried messaging Ian about his intake adapter but get no replies, he gets to read them but no reply. I expressed my intention to purchase the adapter, still no reply.
If designing this from scratch, plus some help with the templates Pete Bell has supplied us, is 90 mm a good enough diameter to work with? Do I need to work around any pipe work or components when making the tube the hose will clamp on to? I have a left hand drive Defender so I'm sure there will be stuff in the way. The truck is in the shop right now so I can do the poking around myself. Any assistance you guys can give me will greatly help out.
The Naka kit that comes in via the top of the wing is also nice but if memory serves, the size of the pipe and tube is only 70 mm? I already have a Mantec installed and would like to use that as much as possible.
Post #762973 12th Mar 2019 4:34am
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
I made my own outof a quality piece of 4 inch flexible pipework. A wing top plate with a 4 inch hole in it (again DIY) then a 4 inch ā€œRAMā€ air intake with two of the sides trimmed to fit under a RH snow cowl.
 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #763006 12th Mar 2019 10:41am
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
I fitted the intake to my 2.4 which runs a mid-level tune, did the airbox mods and to me it is one of the best things I have done. Engine picks up much more quickly. Can absolutely recommend it. m
Post #763082 12th Mar 2019 8:58pm
CarMan
If it helps at all, but probably not, the HVAC guys we use at work are adamant you need smooth pipe work so the free flow of air isn't impeded šŸ‘šŸ» Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #763084 12th Mar 2019 9:11pm
Roy5695
the 4" pipe I have used isn't smooth on the inside, but it is roughly twice the diameter of the turbo inlet pipe (which is a smooth upgraded silicone item) the air also has to pass through the air filter afterwards so any pre-filter smoothing will be well and truly disrupted in my eyes. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #763491 14th Mar 2019 8:49pm
PCM
Sorry for redirecting an old thread, but before I go for a tune I’m looking to streamline the air intake.
I’m not interested in a raised snorkel intake, just improve the standard setup. Has anyone brought anything out recently or is my best option still to mess on with the impeller and cut bits out of the standard box.
Surely there is a better option. Someone is missing a trick here.
Post #816642 23rd Feb 2020 11:12pm
If you don't want a snorkel then have a search for Nugget Stuff induction kit. Darren
Post #816643 23rd Feb 2020 11:15pm
PCM
Is that the beautiful one that’s about Ā£700?
If so it’s above my pay grade. Too many other ā€˜shiny things’ to buy
I was kind of hoping to one would have produced a hose and fixing kit at least.
Post #816645 23rd Feb 2020 11:19pm
Page 3 of 5 <12345>
