Home > In Car Electronics > Rear speaker housings 90 TDCi |
Farmer58za Member Since: 20 Jan 2017 Location: Worcestershire Posts: 85 |
Hi All
I'm in the process of getting a radio/CD for my 90 TDCi, which was never fitted with one. The front speakers appear to be easy to fit behind the speaker covers provided. However, the rear speaker housings look like they have been blanked off. Is there a removable cover there or do I have to cut the housings to fit the speakers? Thanks in advance. David Dave's not here man... |
24th Mar 2017 5:00pm |
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 495 |
When i fitted speakers to my heritage, i went and bought replacement trims from land rover, they weren't too expensive. There are two different part numbers with and without holes. I did this in case it was necessary to put it back to standard. Otherwise, you could simply cut holes in your existing ones. Buying new ones meant i didn't have to worry about getting my holes perfectly round and centred or the screw holes in the right places....
The speaker wires were already in behind the trims, so easy enough to connect. However, at the front the factory transposed the speaker/tweeter wire positions on one side, that was a pita! Current Steeds: 2015 110 UW in Grasmere Green 2003 BMW F650 the Hack 2000 Elise 1992 Ducati 888 (no longer in bits, yahoo) 1990 TDR 250 (in bits again) 1988 TDR 250 (no longer in bits) and for sale Last edited by doublea on 24th Mar 2017 9:02pm. Edited 1 time in total |
24th Mar 2017 8:59pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20487 |
Do you have a picture at all? No Guts, No Glory.
24th Mar 2017 9:01pm |
Click image to enlarge [/img] Dave's not here man... |
25th Mar 2017 12:10am |
Hi Balzer
Thanks for the advice and part numbers. That was a great help! Regards David Dave's not here man... |
25th Mar 2017 8:46am |
