Home > In Car Electronics > Rear speaker housings 90 TDCi
Farmer58za
South Africa 2012 Defender 90 Puma 2.2 SW Tamar Blue
Hi All
I'm in the process of getting a radio/CD for my 90 TDCi, which was never fitted with one. The front speakers appear to be easy to fit behind the speaker covers provided. However, the rear speaker housings look like they have been blanked off. Is there a removable cover there or do I have to cut the housings to fit the speakers?
Thanks in advance.
David Dave's not here man...
Post #611867 24th Mar 2017 5:00pm
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
When i fitted speakers to my heritage, i went and bought replacement trims from land rover, they weren't too expensive. There are two different part numbers with and without holes. I did this in case it was necessary to put it back to standard. Otherwise, you could simply cut holes in your existing ones. Buying new ones meant i didn't have to worry about getting my holes perfectly round and centred or the screw holes in the right places....
The speaker wires were already in behind the trims, so easy enough to connect. However, at the front the factory transposed the speaker/tweeter wire positions on one side, that was a pita! Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #611931 24th Mar 2017 8:59pm
Do you have a picture at all? Thumbs Up No Guts, No Glory.
Post #611933 24th Mar 2017 9:01pm
Farmer58za
[/img] Dave's not here man...
Post #611976 25th Mar 2017 12:10am
Balzer
Brazil 2011 Defender 90 Puma 2.4 X-Tech LE Zambezi Silver
Hi Farmer58za,
There are two different rear speaker housing. One with speaker hole and one without speaker hole.
This is the number of your trim without the hole: ERQ500190PMA and ERQ500180PMA
You can cut it out but the speaker will not be perfectly fitted.
This is the number of the trim with speaker hole:ERQ500130PMA and ERQ500120PMA. Thumbs Up
Post #611981 25th Mar 2017 2:44am
Farmer58za
Hi Balzer
Thanks for the advice and part numbers. That was a great help!
Regards
Post #611999 25th Mar 2017 8:46am
