Home > Td5 > Problem with indicators after bashing a pole
Maarten
South Africa 2002 Defender 110 Td5 SW Alpine White
Hi everybody
When reversing yesterday,I managed to bump into a pole which broke my right rear indicator lens and globe.I have replaced the globe(have not been able to get a new lens yet) and the indicators are working.However,whenI use the right hand indicators,it is still clicking in the fast mode as if a globe is dead.Both the front and rear lights are flashing as well as the side one - it is just going at fast mode.Using the left indicators there is no problem - going at the normal rate.Any ideas?
Thanks
Maarten
Post #611400 22nd Mar 2017 2:45pm
ibexman
sounds like a short or somethings gone to earth
Post #611409 22nd Mar 2017 4:03pm
Eduardo
Check the fuse of the indicator.
Sometimes, happens that blowup when you smash the lamp (happens to me some days ago Embarassed ) Eduardo
Post #611459 22nd Mar 2017 7:44pm
Maarten
Hi
Would that be on the fuse box behind the gear lever or the one inside the ECU box?
Thanks
Post #611468 22nd Mar 2017 8:03pm
4RF RDS
Main fuse panel. And you probably have short or bad earth on that light socket. Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #611477 22nd Mar 2017 8:18pm
