![]() | Home > Td5 > Problem with indicators after bashing a pole |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2956 ![]() ![]() |
sounds like a short or somethings gone to earth
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Check the fuse of the indicator.
Sometimes, happens that blowup when you smash the lamp (happens to me some days ago ![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Maarten Member Since: 13 Apr 2016 Location: Witbank Posts: 8 ![]() ![]() ![]() |
Hi
Would that be on the fuse box behind the gear lever or the one inside the ECU box? Thanks |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 959 ![]() ![]() ![]() |
Main fuse panel. And you probably have short or bad earth on that light socket. Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
