Home > Technical > Dashboard engine warning light
Dtm
United Kingdom 2008 Defender 90 Puma 2.4 HT Coniston Green
Hey
Im trying to track down a starting fault and have noticed that on start up/when i turn the key to the on position the engine warning light flickers as in this video :
Is this normal? as im wondering if there is a fault in my instrument cluster for some reason. . .
Thanks in advance
main thread trying to find starting fault:
http://www.defender2.net/forum/topic52555.html
Post #608302 10th Mar 2017 7:51am
dorsetsmith
4 MIL light ECU DTC
28 battery/ charge Alt frailer will be lit when starting or if your charge Alt has failed then engine is running
29 Low oil presser will be lit when starting but go out with engine run
Post #608316 10th Mar 2017 9:40am
Dtm
Thanks dorsetsmith
Its the MIL light ECU DTC one that I'm questioning.
If you watch the video when the key is turned it comes on for half a second, then flickers, then stays on constantly untill the engine is running. (Or stays on when she is faulting! As engine dosent start)Is the flicker normal?
Thanks
Post #608330 10th Mar 2017 10:58am
