Home > Technical > Dashboard engine warning light |
Dtm Member Since: 11 Feb 2017 Location: Essex Posts: 11 |
Hey
Im trying to track down a starting fault and have noticed that on start up/when i turn the key to the on position the engine warning light flickers as in this video : Is this normal? as im wondering if there is a fault in my instrument cluster for some reason. . . Thanks in advance main thread trying to find starting fault: http://www.defender2.net/forum/topic52555.html |
10th Mar 2017 6:51am |
Thanks dorsetsmith
Its the MIL light ECU DTC one that I'm questioning. If you watch the video when the key is turned it comes on for half a second, then flickers, then stays on constantly untill the engine is running. (Or stays on when she is faulting! As engine dosent start)Is the flicker normal? Thanks |
10th Mar 2017 9:58am |
