![]() | Home > Td5 > Engine tuning advice? |
BCdefender Member Since: 26 Oct 2015 Location: Nanaimo Posts: 211 ![]() ![]() ![]() |
Does anyone have a guide as to how to solder on the chip? 1999 Defender 110 2003 P38 2007 RR SC "And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it." My build thread: http://www.defender2.net/forum/topic47750.html |
hmm...
I wonder if the best option would be to buy a new ecu and get it chipped and then mailed to me... 1999 Defender 110 2003 P38 2007 RR SC "And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it." My build thread: http://www.defender2.net/forum/topic47750.html |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 691 ![]() ![]() ![]() |
In the older type TD5 engine ECU - marked MSBxxxxxx the memory chip is in PLCC package. You need some proper tools for desoldering the old chip, and soldering back new chip or socket. I have done it few times - it is not hard, when you are experienced with soldering. Many times I was repairing damaged ECUs, when someone tried these soldering, and was not really good in it.
One small problem is, that original memory chip and whole board, is covered with some thick protective coating, and it works like a glue, between chip and board. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
Probably it is but it is still not plug and play.
The injector codes have to be programmed. (can be done by the tuner if you tell them the codes) The AS10 (alarm ecu) has to learned to the Engine ECU. But you could buy one from the tuner too and let them be programmed. However if you have remote keyfob then they have to be learned again too. But some tuners like Bell can make the ecu not looking for the AS10 anymore. So all your build in security is switched off but the ECU will be plug and play. But if you go for the standard tune, not specially made for your specific td5, why don't you go for a good tuning box what is plug and play. Like the PSI powerbox I use. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
