Home > Maintenance & Modifications > Diff breather removal
Page 2 of 2 <12
Naycrx
That's brilliant...... i was wondering if you could blow down it .... I'll add a longer pipe to the breather so my heads not in the engine bay.......
How does the breather come off the transfer box?
Post #1029198 25th Mar 2024 7:58am
andy63
The breather is fitted to the top of the box using a banjo type bolt.. Not the easiest to get at unless you access from the cab after removing the plate under the cubby box👍
Post #1029321 26th Mar 2024 1:29am
landy andy
You don’t need to remove it if wanting to blow through it as you can just remove filler plug, and then blow down pipe, you will hear it, and feel no resistance. Or if you just want to extend it us a tight fitting rubber hose over the two ends to join them together.
Post #1029333 26th Mar 2024 9:19am
Page 2 of 2 <12
