landy andy
Naycrx wrote:That's brilliant...... i was wondering if you could blow down it .... I'll add a longer pipe to the breather so my heads not in the engine bay.......
How does the breather come off the transfer box?
You don’t need to remove it if wanting to blow through it as you can just remove filler plug, and then blow down pipe, you will hear it, and feel no resistance. Or if you just want to extend it us a tight fitting rubber hose over the two ends to join them together.
26th Mar 2024 8:19am |
