Home > Td5 > Fitting a td5 discovery transferbox into my 90
Page 2 of 2 <12
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
Not the best photo but this is a rear output from a D2
The casting isnt machined for the speedo drive.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #601845 14th Feb 2017 8:03pm
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
I have purchased a 41D disco box without the speedo drive. I have been told that I may need to use shims where the output housing is mated against the box? anyone needed to do this?
Post #601986 15th Feb 2017 2:31pm
jst
what goes in that top hole then? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #602018 15th Feb 2017 4:59pm
^^^ Nothing. the disco2 gets it ground speed off of the ABS sensors.
I recently swapped the t/box over on my 110 to get rid of an annoying whine. the later box I got was an ex disco2 model with no dofflock or rear hole for the speedo transducer, so after a few emails with Dave Ashcroft (he was very helpful... I'll post his reply up here later when I get home if anyone's interested), I swapped over the front piece to give me my difflock back (I also changed the pinion bearing and put a new seal in and a new drive flange... which is now leaking...typical LR)
Rear assy needed swapping over. I asked Dave about the shim business; he suggested to re-use the shims that came off of the original setup (mine didn't have any in anyway) and hope that the bearing doesn't end up too tight (or loose)
Anyway, a few thousand miles on and all seems OK.
Post #602024 15th Feb 2017 5:13pm
jst
so its a blind hole then?
i have used D2 boxes and plumbed straight into them for speedo Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #602031 15th Feb 2017 5:32pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
You will also need to transfer the hi lo switch housing from your current t box to the new old 1.222 t box.
it's a simple straight exchange. The defender has migrated, leaving the owner behind.
Post #602177 16th Feb 2017 1:49am
Yessir 'tis
Post #602189 16th Feb 2017 8:39am
Page 2 of 2 <12
