Home > Td5 > Electrical drawings for a 2000 Td5??
dougelec
United Kingdom 2000 Defender 110 2.5 TD CSW Rioja Red
I have a problem with my lights and have managed to get a hold of two sets of electrical drawings for a Td5 but neither seem to tally with my 2000 110 County model. One set of drawings is marked as '1999 MY' but the fuse numbers for the lighting circuits don't match my fuse box, see photo, and the other, marked as 2002, has more fuses. Is there another drawing for the 2000 model or am I reading the drawing incorrectly? Thanks in anticipation.
Post #599939 7th Feb 2017 8:53pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
Please explain what does not match up
You have two rows of 10 fuses in the diagram and two rows of 10 fuses in the photo
All fuses are of the correct amps for their positions ?????
Post #599978 7th Feb 2017 10:08pm
dougelec
Sorry, I realise I didn't explain this very well.
What I'm mean is according to the 1999MY drawings the head lights are fed from fuses 16 and 17 but on my fuse box it's 13 and 14, as per the photo. They, and other supplies, don't tally up.
Post #599981 7th Feb 2017 10:17pm
dorsetsmith
Your centre fuse box lid is from TDI 300 fuse lay out is not the same Exclamation
All you need to do get the right fuse layout label Exclamation or print out the two below
Post #600040 8th Feb 2017 9:29am
dougelec
Thanks very much Dorsetsmith, that would certainly explain a lot and put an end to a lot of head scratching.
Post #600157 8th Feb 2017 6:30pm
Scottyboy
Germany 1999 Defender 110 Td5 SW Chawton White
Fuse box symbols Td5
I know this post is old; however, I have a 1999 Td5 110 CSW with the same issue as dougelec. My fuse panel forward of the shifter and fuse layout do not match the wiring diagram for a 1999. Any ideas why this may be? Dougelec’s photos look exactly like my layout and it is an unmodified Td5. The main thing I’m looking for is an explanation of the symbols. Thanks!
Post #1039514 9th Jul 2024 12:08pm
Martin
Site Admin
The actual answer is that the fuse box labels have the fuses in reverse order compared to the wiring diagrams.
To match the wiring diagrams, the top row should be labelled F10 -> F1, and the bottom row F20 -> F11  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1039515 9th Jul 2024 12:20pm
Martin
Site Admin
YQS101790 and YQS000010 both apply to 1999MY-2001MY Defender Td5s.
The difference of note is a minor change to the graphic for the hazard warning lights above fuse box label 8 (wiring diagram fuse 3!)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1039516 9th Jul 2024 12:26pm
Scottyboy
Well, that makes perfect sense. It is exactly backwards. Thank you!
Post #1039517 9th Jul 2024 12:26pm
Martin
Site Admin
You're welcome  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1039520 9th Jul 2024 12:30pm
