Home > Maintenance & Modifications > Replacement steering wheel grief. |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3773 |
It looks to be 48 splines counting the sprockets.
I like the look of it (if it will fit a series) Good luck fitting it you may need a Boss but I'm not sure? is there any name / make on the wheel you can look up? |
1st Feb 2017 3:03pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello petestaunch
A 2008 Station Wagon looks to be a 36 Spline...but the Steering Wheel looks good so maybe source a replacement Boss and you can use it...check the PCD (Hole Positions) for any swap over Boss, pairing it to your Wheel Click image to enlarge Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
1st Feb 2017 3:10pm |
gabe3105 Member Since: 25 May 2015 Location: Grimsby Posts: 237 |
Judging by that table then, his hard top will be 48 spline, but the steering wheel in the picture is 36?
1st Feb 2017 3:38pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1767 |
By my count steering wheel looks to be a 36 spline as would make sense for for a td5.
The puma could be 36 or 48 dependent on version, but as it doesn't fit you can assume 48! Should be able to source a 48 spline boss that will mate to your wheel. |
1st Feb 2017 5:14pm |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
Looks like a Mountney Classic wheel, why not give them a call
http://www.mountneyltd.com/2014-08-18-04-2...ssic-range 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
1st Feb 2017 5:36pm |
petestaunch Member Since: 19 Nov 2016 Location: Wales Posts: 65 |
Again, possibly moronic question but I am just counting the little ridges, correct? In that case it's 36 spline.
I was just told by the mechanic that 'it wouldnt fit'. Is there any other reason it wouldnt fit? Thank you all for your help, and yes it looks like a Mountney. Heading to their site now |
2nd Feb 2017 8:38am |
Hi petestaunch
Your replacement wheel is fitted with a 36 Spline Boss (yes the 'ridges' are counted) If it doesn't fit your Defender then you (probably) have a 48 Spline Steering Column (Take the existing wheel off and count the Splines on the Column) Click image to enlarge 36 Spline Boss 48 Spline Steering Column As it's easier to change the Boss than your Steering Column your options are: 1 Change the Boss to a 48 Spline Unit 2 Sell your Replacement wheel and start again 3 Do nothing You have to answer your initial question...
2nd Feb 2017 11:28am |
Skip.
Appreciate you taking the time. Thank you. Pete |
2nd Feb 2017 11:31am |
That's OK, I really like your replacement wheel...so if it were me, i'd sort this out so it could be fitted... SKIP
2nd Feb 2017 11:43am |
Right
Mountney werent very helpful. Could someone please just post a link to a suitable boss. I dont think I need one made out of Carbon Fibre or anything crazy. Thanks Pete |
2nd Feb 2017 4:00pm |
If you can measure the pcd then yes.
PCD being the size of the circle that all the bolts sit on the perimeter of. |
2nd Feb 2017 4:50pm |
Click image to enlarge |
2nd Feb 2017 5:19pm |
Measure the PDC of your location screws then check with any Boss supplier
This may work... http://www.exmoortrim.co.uk/land-rover-48-...0-vat.html Download the Installation Advice also Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
2nd Feb 2017 5:28pm |
Here's the 48 spline Mountney boss on LRParts
http://www.lrparts.net/defender-steering-w...lines.html 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
2nd Feb 2017 6:05pm |
