Home > Puma (Tdci) > Fault Codes |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
Can anyone help me identify these fault codes:
9A75-01 9A81-64 Merlin |
1st Feb 2017 12:33pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello Merlin
I have the DTC Ford Land Rover Fault Code List in pdf form (97 pages) Revision Date 17th October 2007 PM Me your e-mail address and I'll send it over... However, almost all codes are listed as P0000 (P and then 4 numbers) Some are listed as P000A (P and then 3 numbers ending with another Letter) A quick look doesn't appear to show what you have listed... No doubt the DTC Fault Code Guru's will be along shortly... SKIP https://www.defender2.net/forum/topic83242.html |
1st Feb 2017 2:19pm |
I used a Nanocom and went into the 'other' settings on the Puma selection. It isn't a powertrain code, but one of the other codes. I'm suspecting ABS or similar.
Merlin |
2nd Feb 2017 3:13pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
****.64 may be associated with DPF?
Unusual set of codes you have there?? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
2nd Feb 2017 3:16pm |
Thanks for the thought, only I don't have a DPF. 2008 model. Merlin
2nd Feb 2017 6:11pm |
xmotor Member Since: 17 Jan 2024 Location: la balme de sillingy Posts: 20 |
Hi
I have got the same fault and my defender 24. TD4 don't want to start? F000-46 9A75-01 9A81-64 1602-31 C401-68 E101-00 Nanocom |
23rd Jan 2024 4:04pm |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 591 |
Did anybody get to the bottom of these codes
27th Dec 2024 5:13pm |
Yes
It was the calculator immobilized I send it to BAS in England to remove the immobilization |
27th Dec 2024 5:48pm |
The 9A75 and the F000 were present when my ecu and alm were not synched. Now they are these have both gone.
27th Dec 2024 5:57pm |
