Home > Puma (Tdci) > Fault Codes
Merlin
Fault Codes
Can anyone help me identify these fault codes:
9A75-01
9A81-64
Merlin
Post #598258 1st Feb 2017 12:33pm
X4SKP
Hello Merlin
I have the DTC Ford Land Rover Fault Code List in pdf form (97 pages) Revision Date 17th October 2007
PM Me your e-mail address and I'll send it over...
However, almost all codes are listed as P0000 (P and then 4 numbers)
Some are listed as P000A (P and then 3 numbers ending with another Letter)
A quick look doesn't appear to show what you have listed...
No doubt the DTC Fault Code Guru's will be along shortly... Thumbs Up
 SKIP
Post #598271 1st Feb 2017 2:19pm
hornet
Re: Fault Codes
9A75-01
9A81-64
Merlin
Which diagnostic device did you use and is it a failure from a TDCI? I really looks strange, maybe another format....
Post #598468 2nd Feb 2017 4:42am
Merlin
I used a Nanocom and went into the 'other' settings on the Puma selection. It isn't a powertrain code, but one of the other codes. I'm suspecting ABS or similar.
Merlin
Post #598603 2nd Feb 2017 3:13pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
****.64 may be associated with DPF?
Unusual set of codes you have there?? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #598604 2nd Feb 2017 3:16pm
Merlin
Thanks for the thought, only I don't have a DPF. 2008 model. Merlin
Post #598653 2nd Feb 2017 6:11pm
xmotor
France 2011 Defender 90 Puma 2.4 CSW Barolo Black
Have you find problem?
Hi
I have got the same fault and my defender 24. TD4 don't want to start?
F000-46
9A75-01
9A81-64
1602-31
C401-68
E101-00
Nanocom
Post #1022299 23rd Jan 2024 4:04pm
