Home > Tdi > TDi flywheel thickness
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
I had my 200 tdi flywheel re surfaced some time ago ready for a new engine build.
I didn’t check the thickness before it went to the machine shop, but now I have come to use it I have and its undersize Big Cry 36mm!! (workshop manual states 36.96 minimum!).
Will the flywheel be okay to use or will the clutch not engage properly? Or will I have to purchase a new one and accept that I now have a large paper weight??
Post #597654 30th Jan 2017 4:07pm
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
Hi matt, I cant see 1 mm making a lot of difference. the push rod self adjusts as clutch wears, ,
Post #597918 30th Jan 2017 10:51pm
dorsetsmith
But its the presser plate that holds the clutch friction plate in palace onto the fly wheel when in drive
not land rover but you can see below
but having had a look at clutch side of 200tdi flywheel, you may be ok or may be not see below
http://www.ebay.co.uk/itm/DISCOVERY-1-DEFE...3641.l6368
Post #597958 31st Jan 2017 9:17am
Blackhat90
Our is different setup from that, the release arm is free floating. and Hydrolic pushrod, 1 mm farther away would not be felt, tractors used to get flywheel skimmed,, .
Post #598119 31st Jan 2017 7:52pm
shaggydog
Tdi Flywheels are thickness critical because they can suffer from cracking. They also are a big part in managing the engine RPM. If the flywheel is reduced in thickness too much the weight is lowered to the point the engine can over speed which causes damage to the internals. Or so I'm told.
I managed to find a reasonable replacement at LR Direct as at the time mine went all I could find were in the £300-400 price mark Shocked
Here is what mine looked like
The dishing and heating on it is still unexplained but the theory was in its past it had been machined badly and then allowed to sit for a long time which caused pockets of rust to form and then eventually the whole face was so distorted the clutch gave out as it was not really contacting very well. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #598575 2nd Feb 2017 1:17pm
Defendermatt
So I went to my local spares shop and measured a couple. Which were all undersize Shocked
They were all non genuine. But I would have thought that if the dimension was so important then it would be something that even the after market manufacturers could get right.
Post #598815 3rd Feb 2017 12:45pm
shaggydog
You would hope so Shocked
Advice I was given was by a senior LR tech at a dealership who had been there since they were selling N/A Diesels so I have no reason to doubt him.
That said, if all the aftermarket ones are out of spec then may not be so critical? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #598818 3rd Feb 2017 1:11pm
Defendermatt
An update on the flywheel situation.
I have now measured a total of 4 flywheels. 2 used. 1 skimmed and 1 new oem.
All of which measured undersize of the minimum of 36.96, between 35.70 and 36.00 ish mm. So I have stuck with the one I had skimmed and decided that the WSM must be printed incorrectly Laughing
Post #601470 13th Feb 2017 2:47pm
shaggydog
Should be fine then Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #601771 14th Feb 2017 1:03pm
