Home > Technical > Washer jets replacement |
thompjas Member Since: 07 Mar 2014 Location: Northants Posts: 36 |
to remove, you need to access from inside the vehicle and unscrew a nut on the back of the jet housing - you just need to follow the water pipe with your fingers to the back of the jet.
You will first need to remove the top of the dash (assuming its pre-Puma models !) here is a crappy photo, but shows the back of the jet and pipe Click image to enlarge |
24th Jan 2017 9:40am |
ukmiitchellx Member Since: 04 Jan 2017 Location: Cornwall Posts: 27 |
I did this last week, I couldn't get movement on the spanner so what I did was get my dad to hold the nut still with the spanner then I undid the jet from the outside, it was fiddly but it worked!
24th Jan 2017 9:44am |
danridge Member Since: 28 May 2013 Location: Bath Posts: 438 |
Thanks guys much appreciated
27th Jan 2017 4:05pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20294 |
Probably is best with an extra pair of hands if you can.
I remember the rear was fiddly but that has good access and you can reach both side. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
27th Jan 2017 4:36pm |
madmac Member Since: 22 Jan 2017 Location: Midlands Posts: 6 |
I did this last weekend on my 110.
First when people say just access it through the ash tray hole they must have tiny hands, plus there wasn't much slack on the tube. So top of dash out. TOP TIP Doing the job on my own I used a G clamp to hold the outer nozzle while I undid the nut to stop it from turning as well. |
5th Feb 2017 12:11am |
Thanks guys
5th Feb 2017 9:45am |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
If you need to replace just the nozzle, you can pop the new one off, and fit it to the old "tube"
5th Feb 2017 9:52am |
