Home > Technical > Washer jets replacement
danridge
United Kingdom 2004 Defender 90 Td5 XS CSW Java Black
Hi guys does the jets/squirter unit just pull off the bulkhead from the outside? I had the dash off recently and I can't see a way of getting to the back of the squirter assembly due to the way the dash Metal structure is formed.
Many thanks.
Post #595827 24th Jan 2017 9:29am
thompjas
to remove, you need to access from inside the vehicle and unscrew a nut on the back of the jet housing - you just need to follow the water pipe with your fingers to the back of the jet.
You will first need to remove the top of the dash (assuming its pre-Puma models !)
here is a crappy photo, but shows the back of the jet and pipe
Post #595831 24th Jan 2017 9:40am
ukmiitchellx
I did this last week, I couldn't get movement on the spanner so what I did was get my dad to hold the nut still with the spanner then I undid the jet from the outside, it was fiddly but it worked!
Post #595832 24th Jan 2017 9:44am
danridge
Thanks guys much appreciated
Post #596765 27th Jan 2017 4:05pm
Probably is best with an extra pair of hands if you can.
I remember the rear was fiddly but that has good access and you can reach both side. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #596774 27th Jan 2017 4:36pm
madmac
United Kingdom 1996 Defender 110 300 Tdi HT Alaska White
I did this last weekend on my 110.
First when people say just access it through the ash tray hole they must have tiny hands, plus there wasn't much slack on the tube.
So top of dash out.
TOP TIP Doing the job on my own I used a G clamp to hold the outer nozzle while I undid the nut to stop it from turning as well.
Post #599167 5th Feb 2017 12:11am
danridge
Thanks guys
Post #599190 5th Feb 2017 9:45am
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
If you need to replace just the nozzle, you can pop the new one off, and fit it to the old "tube" Thumbs Up
Post #599191 5th Feb 2017 9:52am
